on 17-02-2020 19:31
Inspire of investing in boosters there are areas in my property where there is no wifi signal.
I am considering investing in a Mesh system (eg Google Nest, BT, disc, Netgear Orbi).
Any recommendations as to which system is most compatible with Virgin Hub 3.0 and provides best coverage and speed
Answered! Go to Answer
13-11-2021 10:56 - edited 13-11-2021 11:11
Spoke to soon, now battling with Sky Q boxes
update may have found solution to this, not mine found elsewhere will keep updated on progress
added sky q main and sky mini to reservation list under advanced in deco app and turned off mesh for each in deco app as they won’t be roaming
seems to stay connected 🤞
on 16-11-2021 10:25
This is a great thread. Thanks all so far.
on 20-11-2021 12:23
Following this thread with interest, am about to buy mesh system ( Google WiFi looking good as reduced price). Will be using as main router connected to Hub3, I didn't realise about the attached ethernet cables to the Hub3, lucky I have a Gb switch that has couple spare ports.
If I set the SSID and password that i currently have on the Hub3 as the one for the new router this should mean I won't have to reconnect all my devices? Such as smart plugs etc.
on 20-11-2021 13:39
@Bob747 wrote:If I set the SSID and password that i currently have on the Hub3 as the one for the new router this should mean I won't have to reconnect all my devices? Such as smart plugs etc.
Yes, basically, if you use the same ssid and password as you currently have on your hub 3, then there is no need to update your devices. They will just connect as normal.
on 20-11-2021 14:52
How would I connect my Deco Mesh System to Modem mode? as I was under the impression that to change the Hub 3 to Modem mode you would have to have another 3rd party Hub connected to the original Hub 3, then connect your mesh system to the 3rd party Hub and then change Hub 3 to modem...as thats what I thought.....
so are you saying that I do not need a 3rd party Hub and that I can connect my Deco mesh system to port 1 on Hub 3 and then change Hub 3 to Modem mode and it will be far better???
Thanx
20-11-2021 14:58 - edited 20-11-2021 14:59
@Huckle1 wrote:<snip>. so are you saying that I do not need a 3rd party Hub and that I can connect my Deco mesh system to port 1 on Hub 3 and then change Hub 3 to Modem mode
Yes and no. Disconnect all Ethernet cables from the Hub, set the Hub to modem mode and switch it off. Set the Deco for Router mode and leave switched on. Connect the Deco WAN port to the Hub. Power on the Hub. This sequence only needs to the first time you do this.
on 20-11-2021 16:30
on 21-11-2021 18:06
Looks like I might be going for the Tenda MW12, has triband and is going for £135 for x3 units on Quzo.net. That's£20 cheaper than Amazon! Anyone else using Tenda mesh, should I be taking this to another posting?
on 23-11-2021 18:33
Hi @Bob747, thanks for coming back to us.
Please do keep us updated with how things go. Remember if you ever need assistance in the future, our fantastic community and forum team are always willing to lend a hand.
Lee_R
on 02-12-2021 14:47
Hi all ,
this is a great thread for starters like me ,helped me a lot to configure my setup. I am with virgin and have deco.
Recently I upgraded my BB speed to 500mbps ..! hub is in modem mode, deco in router mode. All fine , everything is working fine apart from speed.
When I checked the speed the deco app its shows 500+mbps properly but when I check the speed using fast.com or speediest.net from my laptop or from my phone , I can see I am only getting 100mbps. Anyone else facing this issue , can someone help me to fix this speed thing.
thanks
