on 21-09-2021 20:51
Hi all, over the past month my Hub 3 router has become more and more unrealiable in terms of internet stability and latency. I have a Windows PC that is plugged directly into the router via Ethernet. I have the M200 Fibre Broadband package and have recently been getting around 15-50 Mbps:
There are other devices on my network but nothing downloading or causing other activity.
However my speeds are not the issue, it's the error log in my router status:
21/09/2021 19:55:49 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2021 19:55:48 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2021 19:54:47 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2021 19:53:47 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2021 19:52:1 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2021 19:51:59 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2021 19:51:58 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2021 19:51:58 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2021 19:51:38 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2021 19:51:38 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2021 19:51:37 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2021 19:51:37 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2021 19:51:36 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2021 19:51:36 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2021 19:51:34 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2021 19:51:34 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2021 19:51:33 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2021 19:51:31 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2021 19:51:30 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
I get these Sync Timing Failure and RCS partial Service errors all day long, with random latency errors too and spikes.
Here are my other router stats:
1 147000000 -0.9 40 256 qam 2
2 155000000 -0.5 40 256 qam 3
3 163000000 -0.5 38 256 qam 4
4 171000000 0.2 40 256 qam 5
5 179000000 0.4 40 256 qam 6
6 187000000 0.2 40 256 qam 7
7 195000000 0.4 40 256 qam 8
8 203000000 0 40 256 qam 9
9 211000000 -0.2 40 256 qam 10
10 219000000 -0.5 38 256 qam 11
11 227000000 -0.7 40 256 qam 12
12 235000000 -0.5 40 256 qam 13
13 243000000 -0.5 40 256 qam 14
14 251000000 -0.5 40 256 qam 15
15 259000000 -0.5 40 256 qam 16
16 267000000 -0.4 40 256 qam 17
17 275000000 -0.2 40 256 qam 18
18 283000000 0 40 256 qam 19
19 291000000 0 40 256 qam 20
20 299000000 0.2 40 256 qam 21
21 307000000 -0.2 40 256 qam 22
22 315000000 0 40 256 qam 23
23 323000000 0 40 256 qam 24
1 Locked 40.9 9160693 2708227
2 Locked 40.3 10183274 2721463
3 Locked 38.9 9723426 3643753
4 Locked 40.9 10402721 4277133
5 Locked 40.9 6116476 453848
6 Locked 40.9 9041255 1616879
7 Locked 40.9 9545870 2207988
8 Locked 40.3 7552805 889202
9 Locked 40.9 7917316 1056479
10 Locked 38.6 9966032 2902479
11 Locked 40.3 9491599 3204529
12 Locked 40.3 8455846 1399378
13 Locked 40.3 6804677 679626
14 Locked 40.9 5556183 370228
15 Locked 40.3 4701373 236543
16 Locked 40.3 3256033 87864
17 Locked 40.3 2113563 26129
18 Locked 40.3 2019493 24291
19 Locked 40.3 1388084 8015
20 Locked 40.3 951525 2134
21 Locked 40.3 1038150 3063
22 Locked 40.3 527011 255
23 Locked 40.9 132350 0
1 60300000 51 5120 64 qam 1
2 39400000 51 5120 64 qam 4
3 53700000 51 5120 64 qam 2
4 46200010 51 5120 64 qam 3
1 ATDMA 0 0 5 0
2 ATDMA 0 0 34 0
3 ATDMA 0 0 12 0
4 ATDMA 0 0 11 0
Can VM please help, can I get an engine out to look at these issues? I've called 0800 561 0061 and there are no service issues in my area either. I've also hard reset my router and I still get the errors.
Thanks a lot for any help.
Answered! Go to Answer
on 16-10-2021 08:57
Hi @tomo8281,
Thank you for coming back to us in regards to your ongoing issue. I have been able to locate your account and run some checks on your power levels. I can see that there are some issues with your upstream power levels and that they are not looking so great.
As we cannot resolve this issue remotely, we will need to send out a technician. I will send you a Private Message to confirm some details before I can do this, so please keep an eye out for a purple envelope at the top right corner of your forum page. I will be in touch soon.
Thank you,
on 23-10-2021 14:29
Hi - thanks a lot, the technician came out yesterday and did a bit more troubleshooting - he said it's all good now but could the forum please check these new power levels?
1 139000000 4.6 40 256 qam 1
2 147000000 5.1 40 256 qam 2
3 155000000 5.4 40 256 qam 3
4 163000000 5.5 40 256 qam 4
5 171000000 5.6 40 256 qam 5
6 179000000 5.5 40 256 qam 6
7 187000000 5.5 40 256 qam 7
8 195000000 5.5 40 256 qam 8
9 203000000 5.4 40 256 qam 9
10 211000000 5.1 40 256 qam 10
11 219000000 5 40 256 qam 11
12 227000000 4.5 40 256 qam 12
13 235000000 4.5 40 256 qam 13
14 243000000 4.5 40 256 qam 14
15 251000000 4.9 40 256 qam 15
16 259000000 5 40 256 qam 16
17 267000000 5.1 40 256 qam 17
18 275000000 5.1 40 256 qam 18
19 283000000 5.4 40 256 qam 19
20 291000000 5.5 40 256 qam 20
21 299000000 5.8 40 256 qam 21
22 307000000 5.5 40 256 qam 22
23 315000000 5.5 40 256 qam 23
24 323000000 5.6 40 256 qam 24
1 Locked 40.3 9 0
2 Locked 40.3 18 0
3 Locked 40.9 5 0
4 Locked 40.9 6 0
5 Locked 40.9 20 0
6 Locked 40.3 26 0
7 Locked 40.9 21 0
8 Locked 40.9 19 0
9 Locked 40.3 13 0
10 Locked 40.3 8 0
11 Locked 40.3 10 0
12 Locked 40.3 10 0
13 Locked 40.3 7 0
14 Locked 40.3 33 0
15 Locked 40.9 21 0
16 Locked 40.9 5 0
17 Locked 40.9 8 0
18 Locked 40.3 7 0
19 Locked 40.3 12 0
20 Locked 40.3 26 0
21 Locked 40.9 15 0
22 Locked 40.9 6 0
23 Locked 40.9 22 0
24 Locked 40.3 13 0
1 60300000 45.5 5120 64 qam 1
2 39400000 44.3 5120 64 qam 4
3 46200000 44.5 5120 64 qam 3
4 53700000 45 5120 64 qam 2
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060+voc-b.cm
SFID 305662
Max Traffic Rate 230000061
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 305661
Max Traffic Rate 22000061
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type BestEffort
Thanks so much!
on 25-10-2021 14:51
Thank you for the update @tomo8281.
I am glad to hear our technician was able to help regarding this. I have had a look back end into your power levels and everything seems to be working well. In this case, please continue to monitor your service and let us know if you need any further help.
on 26-10-2021 14:38
Thanks so much. I've marked this issue as solved and can be considered closed
Thanks again.
on 28-10-2021 15:47
Glad to hear that @tomo8281 and please let us know if you have any further issues.
Regards,
Steven_L
on 07-01-2022 11:52
Hi all,
Happy new year - however I am back again with some problems. Last night the internet was terrible - really slow, had to reboot a few times, just wasnt working. I logged onto the router status and saw a LOT of post rs Errors - so I went to bed, woke up this morning and did a power cycle of the router to then post it's status on here to see if anything is wrong. Can someone have a look at below and see if everything is okay? I dont currently have any post rs errors as the uptime is only 2hours or so since reboot. Thanks so much!
07/01/2022 11:45:17 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:36 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2022 21:37:31 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2022 12:19:54 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2022 12:06:23 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2022 11:53:9 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2022 11:53:9 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2022 11:53:6 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2022 11:53:6 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2022 02:26:51 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2021 20:23:32 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2021 19:35:31 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2021 09:12:59 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2021 03:45:10 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2021 21:12:59 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2021 09:12:44 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2021 09:11:49 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2021 09:07:48 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2 46200000 44.8 5120 64 qam 3
3 39400000 44.5 5120 64 qam 4
4 53700000 45.3 5120 64 qam 2
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
1 203000000 5.6 40 256 qam 9
2 211000000 5.5 40 256 qam 10
3 219000000 5.4 40 256 qam 11
4 227000000 5 40 256 qam 12
5 235000000 4.9 40 256 qam 13
6 243000000 4.8 40 256 qam 14
7 251000000 5 40 256 qam 15
8 259000000 5.4 40 256 qam 16
9 267000000 5.6 40 256 qam 17
10 275000000 5.5 40 256 qam 18
11 283000000 5.9 40 256 qam 19
12 291000000 6 40 256 qam 20
13 299000000 6.4 40 256 qam 21
14 307000000 6 40 256 qam 22
15 315000000 6.1 40 256 qam 23
16 323000000 6.3 40 256 qam 24
17 331000000 6.5 40 256 qam 25
18 339000000 6.8 40 256 qam 26
19 347000000 6.5 40 256 qam 27
20 355000000 6.4 40 256 qam 28
21 363000000 6 40 256 qam 29
22 371000000 5.8 40 256 qam 30
23 379000000 5.9 40 256 qam 31
24 387000000 6 40 256 qam 32
1 Locked 40.3 5 0
2 Locked 40.3 6 0
3 Locked 40.9 6 0
4 Locked 40.3 5 0
5 Locked 40.9 5 0
6 Locked 40.3 6 0
7 Locked 40.9 0 0
8 Locked 40.9 6 0
9 Locked 40.3 5 0
10 Locked 40.3 5 0
11 Locked 40.3 6 0
12 Locked 40.9 5 0
13 Locked 40.3 5 0
14 Locked 40.9 6 0
15 Locked 40.9 7 0
16 Locked 40.3 5 0
17 Locked 40.9 5 0
18 Locked 40.3 6 0
19 Locked 40.9 5 0
20 Locked 40.3 5 0
21 Locked 40.3 4 0
22 Locked 40.3 7 0
23 Locked 40.3 4 0
24 Locked 40.9 0 0
Cable Modem Status
Item Status Comments
203000000
Locked
Ranged Upstream Channel (Hz)
60300000
Locked
Provisioning State
Online
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID 442344
Min Traffic Rate 0
SFID 442343
Min Traffic Rate 0
on 09-01-2022 12:07
Hi @tomo8281,
I'm so sorry to hear that the issues with your connection have returned. Using the details you've provided when signing up to the forums, I've taken a look and can't see any known area impacting faults currently. Are your issues ongoing today?
If they are, would you mind trying a factory reset of the router to see if that helps at all?
