  • 10
RossCoulbeck
Message 1 of 9
Hub 3.0 Internet keeps dropping over Wifi
For the last few weeks I've had problems with the internet on my laptop. It's connected via wifi to the Hub 3.0 and every so often the internet connection will drop. Most of the time the actual wifi signal stays connected, it just says there is no internet connection. This can happen every few minutes, or every half an hour to an hour. It varies but it has been constantly happening for weeks now.
Disconnecting from the wifi and reconnecting seems to fix the issue, at least until it happens again. I've tried restarting the Hub but I don't think it made much of a difference. Hub itself did feel warm to the touch when I restarted it so that might be something.
Haven't noticed these issues on wired connections, but have on occasion on my phone, although less often.
Hope someone can help, thanks.
  • 10
RossCoulbeck
Message 2 of 9
Re: Hub 3.0 Internet keeps dropping over Wifi
Some details:
13227500003.740256 qam24
23147500003.540256 qam23
33067500003.540256 qam22
42987500003.540256 qam21
52907500003.538256 qam20
62827500003.740256 qam19
72747500003.940256 qam18
8266750000440256 qam17
9258750000440256 qam16
10250750000440256 qam15
112427500004.140256 qam14
122347500004.140256 qam13
132267500004.140256 qam12
142187500004.140256 qam11
152107500004.140256 qam10
162027500004.140256 qam9
171947500004.140256 qam8
181867500004.140256 qam7
191787500004.140256 qam6
20170750000440256 qam5
211627500004.140256 qam4
22154750000440256 qam3
23146750000440256 qam2
241387500004.340256 qam1
1Locked40.33070
2Locked40.33240
3Locked40.32100
4Locked40.32180
5Locked38.91800
6Locked40.31710
7Locked40.31540
8Locked40.31210
9Locked40.31280
10Locked40.31430
11Locked40.31330
12Locked40.32200
13Locked40.3810
14Locked40.31110
15Locked40.31310
16Locked40.3940
17Locked40.31620
18Locked40.329140
19Locked40.31460
20Locked40.31020
21Locked40.9860
22Locked40.9750
23Locked40.3860
24Locked40.3740
13940000044.3512016 qam2
24620000045512016 qam1
32580000043512016 qam4
43260000043.8512016 qam3
1ATDMA0040
3ATDMA0040
4ATDMA0020
  • 10
RossCoulbeck
Message 3 of 9
More details (keeps saying too long for one post):
2018-09-07 09:47:58.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-07 11:15:52.00ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-07 14:53:29.00ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-08 05:22:36.00Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-08 05:22:37.00criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-08 05:22:37.00Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-08 05:26:59.00Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-08 05:27:00.00criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-08 05:27:00.00Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-08 10:29:16.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-10 23:04:31.00ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-11 20:56:41.00ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-12 18:58:56.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-16 16:50:12.00ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-18 00:20:15.00ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-18 10:35:32.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-21 00:31:26.00ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-21 20:12:44.00ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-09-24 15:48:20.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 7.3K
  • 760
  • 1.14K
Legend
Message 4 of 9
Have you checked in the Hub settings whether in "smart wifi" the "enable channel optimisation" feature is ticked (it shouldn't be !!) if so tick the "disable" box ?  Also have you renamed the ssid's of the 2.4 & 5 GHz networks?
  • 10
RossCoulbeck
Message 5 of 9
Not at home at the moment, but I remember that yes that is enabled and no I haven't renamed them. Until I read another post didn't realise this could be a problem. I'll rename to two separate networks.
How come the 'smart optimisation' doesn't work?
  • 7.3K
  • 760
  • 1.14K
Legend
Message 6 of 9
See this discussion.
https://community.virginmedia.com/t5/Networking-and-WiFi/Potential-FIX-for-WiFi-Disconnections/td-p/...
  • 10
RossCoulbeck
Message 7 of 9
Oh.
Well that's not very 'smart' is it.
  • 1.46K
  • 43
  • 163
RedGooner
Knows their stuff
Message 8 of 9
 wrote:
Oh.
Its also could a SuperHub, but there is nothing super about it.
Red (VM SH2 AC Beta tester)
Running on 350Mb VM service with SH3 in Modem Mode, with a ASUS RT-AC5300 router. With this setup I get Fantastic WIRED and WIRELESS Signals in my home. I dont work for VM. But I work in IT, and I know my tech.
My advice is at your own risk.
  • 10
RossCoulbeck
Message 9 of 9
Thanks, this seems to have solved the issue.
