on 09-07-2020 11:50
I've setup an eero system and it seems good but won't play ball for more than a few hours with the Hub 3 when it is modem mode.
It works fine leaving the Hub 3 in router mode but obviously having the 2 WiFi networks broadcasting from virtually the same spot is both pointless and could cause interference with the eero network.
Is it possible to turn off the WiFi on the Hub 3 whilst staying in Router mode?
Answered! Go to Answer
on 13-05-2021 14:06
on 13-05-2021 14:21
Hi @Londoner2021.
Welcome to our community forums and thank you for your first posts.
In regards to disabling your WIFI, when you turn it off as seen here https://www.virginmedia.com/help/virgin-media-hub-turn-off-wireless do the changes revert automatically? How long does it take before the WIFI is enabled?
on 13-05-2021 14:29
@Akua_A wrote:Hi @Londoner2021.
this has been posted about a few times - it was/is supposedly under investigation i think - theres a thread where the OP says it comes back on in 15 mins and shows as on - my experience is that if i turn it off it continues to show as off even though i can access wifi after 10 or 15 minutes
so it would seem to be a bug in the new firmware - maybe you could dig a little and get an answer - or not
on 13-05-2021 14:32
Thank you for letting me know @-tony-.
I will look to pass this to the relevant teams to be investigated.
on 13-05-2021 14:33
Hi @Akua_A
thanks for reply. It reverts to wifi activated quickly, if I leave the hub 3 access page open in the browser it actives once the browser times out the login. If I click on the "Home" tab of the settings page it reverts to activated immediately.
on 13-05-2021 14:35
on 13-05-2021 14:38
Thank you for letting us know. I will get in contact with the team regarding this known fault.
on 13-05-2021 14:41
on 13-05-2021 15:07
AFAIK that dlink is an access point only, so can’t be used as a router?
on 13-05-2021 18:00
