daniel-farmer
Message 1 of 7
How to reset wifi admin password
Hello, around a year ago I had a new box from Virgin Media and I lost the bit of plastic with the wifi and admin password on it, is there any way I can change the admin password with out knowing the admin password?
  • 10.07K
  • 618
  • 1.3K
jb66
Message 2 of 7
Re: How to reset wifi admin password
If you have removed the sticker from underneath the hub then you cannot change the password now
  • 15.4K
  • 1.6K
  • 3.43K
Message 3 of 7
The plastic insert only has the WiFi password.
The label on the base has both settings and WiFi passwords.
daniel-farmer
Message 4 of 7
That is the thing, When my wifi box turned up it only had 2 things with it, one of them being a sticker and the other being a plastic tab (with the passwords on it). and sadly my siblings have lost them both, ?
  • 6.8K
  • 712
  • 1.04K
Legend
Message 5 of 7
If you need it then the only option is to call in and see if they can send you a replacement - they will probably want to charge you for it though - so get your best negotiating patter working ! If you do get one make sure you take a photo of the sticker and store it securely in a backup or cloud.
  • 15.4K
  • 1.6K
  • 3.43K
Message 6 of 7
Are you saying that you have looked on the base of the Hub and there is nothing there?
When I got my Hub 3.0, it came with the plastic insert, a couple of stickers and also a label on the base.
  • 562
  • 26
  • 36
Message 7 of 7
Hello daniel-farmer
Thanks for posting and welcome to the forum. As advised earlier the sticker and plastic tab are only the log in details for accessing the WiFi on devices within your home network.
To access the Hub and make changes to the settings eg password - you can find a sticker on the back or base of the Hub. On there you will find a settings password (different to the WiFi password) and an IP address to use on a browser. Once you're in you can change various settings for the Hub and your connection.
Rob
