on 26-07-2022 10:55
Moved house recently, was on an (attainable) 70/20 Zen VDSL connection on a very solid line - rock solid 4-5ms pings at all times. Was using UniFi APs, no problems at all. We are now using a Virgin M500, using the SH4 and the same UniFi APs. Google home devices cut out all the time (or do the “something went wrong”), page loads are slow at first etc. How much of this is down to the actual connection, and how much is likely down to the SuperHub as a router? If I stick a decent router (UDM pro or similar) behind it, is it likely to behave better?
on 26-07-2022 11:11
100%yes, the hub is a mass produced POS with a dodgy chipset that causes the majoroty of issues.
In modem mode you're just taking the docsis signal and beaming it via better WiFi in the case if a third party router.
Its so VM can keep tabs on your info is the only reason the hub is mandatory as a modem or combined router.
on 26-07-2022 14:34
I have a UDM Pro router and Unifi APs on my 1G connection and get no problems at all. Hubs work well as modems, very badly as routers.
on 26-07-2022 17:02
There’s another factor in that you’re in another house - so it’s a different environment - different layout, construction, neighbours, interference sources and so on.
Regardless you’re likely better off getting a good 3rd party router.
on 27-07-2022 04:40
@Anonymous wrote: Macy's Insite My Schedule100%yes, the hub is a mass produced POS with a dodgy chipset that causes the majoroty of issues.
Thanks for sharing this information.
