@MDub wrote:
Thanks again, I will take a look.
When I connect with the Virgin Hub it doesn't give me the option of 2.5 or 5Ghz, is there any way of changing this?
you need to log into the hub, navigate to wireless signal and give the 2.4 and 5ghz SSID's different names so that you can see the two separate SSIDs
