on 01-08-2021 12:27
How can i get a Hub 4
on 01-08-2021 12:51
If you have a Hub3, there is no gain in getting a Hub4.
on 03-08-2021 12:37
Hey @AnnieMason,
Welcome to the community and thanks for taking the time to post your query on our forums.
Are you having any issues with your current hub or connection that would need a replacement hub? If so, what issues are you currently having?
What is your current broadband speed?
Regards,
Steven_L
on 03-08-2021 15:16
Streaming on my TV is rubbish, keeps dropping out, signal upstairs is non existent, it keeps dropping out. Done the tests and the App says it’s good in those rooms. Done a reset, the hub isn’t buried and I only live in a small house.
on 03-08-2021 15:21
on 03-08-2021 17:54
Its too bad that the hubs were not just modems then nobody would care what hub they have as long as it works.
on 03-08-2021 18:35
Thank you John, that’s a brilliant answer with some great advice. I will attempt to try all that, however, I have no idea how to get into the settings of the Hub…doh🤔. I’ll goggle how to do it.
on 03-08-2021 18:39
on 03-08-2021 18:41
Thanks for coming back to us @AnnieMason.
You can get into the hub settings by putting the following address in your browser 192.168.0.1 and the password that you need for this is shown on the bottom of your hub as the settings password.
Regards,
Steven_L
on 03-08-2021 18:53
John, have you any advice on which hub to buy, I’m clueless.
