on 28-01-2022 19:52
Hi I just bought the nighthawk xr1000 and I've put my hub 4 in modem mode let it boot etc and then connect my new router and the Internet light is always red. Does anyone know what thus could be? Thanks
on 28-01-2022 20:03
have you configured the netgear yet?
on 28-01-2022 20:08
@Dovesterx wrote:Hi I just bought the nighthawk xr1000 and I've put my hub 4 in modem mode let it boot etc and then connect my new router and the Internet light is always red. Does anyone know what thus could be? Thanks
https://www.downloads.netgear.com/files/GDC/XR1000/XR1000_UM_EN.pdf
Page 27
Use the Internet Setup Wizard
You can use the Setup Wizard to detect your Internet settings and automatically set up
your router. The Setup Wizard is not the same as the pages that display the first time
you connect to your router to set it up.
To use the Setup Wizard:
1. Launch a web browser from a computer or mobile device that is connected to the
router network.
2. Enter http://www.routerlogin.net.
A login window opens.
3. Enter the router admin user name and password.
The user name is admin. The password is the one that you specified the first time
that you logged in. The user name and password are case-sensitive.
The Dashboard displays.
4. Select Settings > Setup > Setup Wizard.
The Setup Wizard page displays.
5. Select the Yes radio button.
If you select the No radio button, after you click the Next button, you are taken to
the Internet Setup page (see Manually Set Up the Internet Connection on page 27).
6. Click the Next button.
The Setup Wizard searches your Internet connection for servers and protocols to
determine your Internet configuration.
