MikiH
How do I connect 2.4 GHz LIghts/switches?
I can't connect the switch and lightbulbs I had on my old 2.4 GHz network as I now have a HUB 3 and I can't distinguish between the two like did. Can anyone shed any light please..... Pardon the Pun
  • 15.81K
  • 1.65K
  • 3.57K
Re: How do I connect 2.4 GHz LIghts/switches?
Yes, log in to the Hub 3.0 and change the name of the 5GHz SSID so you can distinguish between the two and connect explicitly to the 2.4GHz one.
MikiH
Thanks, trying that now
  • 10.32K
  • 281
  • 591
Forum Team (Retired) Emma_E
Hi MikiH,
Thanks for getting in touch, I hope the information Ernie_C gave you helped to get things sorted.
If you are still having trouble let us know and we will be happy to take a look for you.
All the best
Emma
