emfa3000
How can I create 2 SSIDs for my bands?
Hello,
I would like to create another SSID so I can manually select which band I use. How can I do this?
  • 1.71K
  • 241
  • 372
DJ_Shadow1966
Super solver
Re: How can I create 2 SSIDs for my bands?
Hello
Open a Web browser (e.g. Internet Explorer) and enter the address http://192.168.0.1 and login using the details on the card of the hub.
To change them independently go to Advanced Settings > Wireless > Security.
Mike
I dont work for VirginMedia all opinions are my own.
39 years in IT.
  • 16.1K
  • 1.68K
  • 3.68K
Just change one (or both) of the SSIDs on the suggested page. You can leave the passwords as they are if you wish.
Click to learn more about VIP
Use Kudos to say thanks
