on 06-12-2022 09:16
Hi there,
I moved into a new build house recently and got fibre optic broadband set up in the living room. The issue is that the signal and speed is 10 times weaker/slower on the 3rd floor (around 30mbps compared to 380mbs downstairs). It look like there's some sort of a Virgin socket on the top floor. See images here:
Can someone tell me what kind of cable this is? And would it be possible to boost the signal by installing another router on the top floor as well using this cable?
Thank you!
Answered! Go to Answer
on 06-12-2022 09:40
on 06-12-2022 09:40
on 06-12-2022 11:25
If your WiFi is ok downstairs there is another option that would give you excellent WiFi on the second and third floors. If there are Ethernet cable run upstairs you could use them or otherwise get an Ethernet cable run from the VM hub to a central location on ideally the top floor. This Ethernet cable can then be connected to a Wireless Access Point or a retail router running in bridge mode. Ethernet cables are fairly thin and easy to hide, I have run some from downstairs up to my loft and they are hidden behind the down pipes.
on 06-12-2022 11:32
