Home hub 4 settings
realbrutal
I recently received the home hub 4 and wondered why the 5ghz band defaults to channel 108? My Wi-Fi adaptor on my pc (pce-ac68) won’t see the 5ghz band because of this as it only accepts channel 44. Is there any way to stop the router from picking this channel automatically? Any help would be appreciated.
Ps. I have to leave Wi-Fi optimisation on because otherwise my Wi-Fi pod will not work so I’m stuck with channel 108 on the 5ghz band.
1 ACCEPTED SOLUTION
Accepted Solutions
The new Wi-Fi adaptor instantly worked on 5ghz. I’m a happy man. Thanks guys!
5 REPLIES 5
gary_dexter
You’ll need to disable smart Wifi. But if you have a pod then it will use whatever channel it seems as the best - 108 being a DFS channel that is usually clear congestion wise.
Channel 108 is within the standard range for 5GHz, I’ve never seen any adapters that restrict you to the lower channels. Have you tried to update the drivers?
I have latest driver for this Wi-Fi adaptor but it’s dated 2017. I’m assuming it’s just not a good driver.
I decided to buy a new Wi-Fi adaptor (pce-ax58bt)
because of this issue. At least this Wi-Fi adaptor has better features (Wi-Fi 6, Bluetooth, windows 11 support and latest Wi-Fi security wpa3). It’s coming today so will let you guys know how it goes. But it’s a very strange issue indeed.
@gary_dexter
You seem to know a lot about DFS channels and DFS 108 an VM pods?
Ive been advised by my IT dept that to use channel 44 s dfs 108 is causing issues with my MS Teams voice quality and calls and videos calls as ppl say they cant hear me for 5-10 secs!!
However if i turn off Smart Wifi Channel Optimization under admin page it stops the pods from working?
Why can't I for arguments sake use manual 5ghz channel 44 and turn off Smart Wifi Channel Optimization!
Shouldn't that work? e.g turn off Smart Wifi Channel Optimization and use manual 5ghz channel 44?
Any help would be appreciated!
VM CS and Tech Support were awful and rude he said i will need to reset router again! No thank you ive changed to the way I like to with new ssid and wifi password etc....
