maccsss
Home hub 3 base light flashing green with solid green WiFi light on
Hi my Home hub 3 has the base light flashing green with solid green WiFi light on, it was fine then just happened
ive checked all connections and tried turning it off and on at the back but the issue remains... also checked my network service online it says it’s all good
is the thing busted or is t just going to sort itself out ?
  • 2.47K
  • 231
  • 616
DaveM
Problem sorter
Re: Home hub 3 base light flashing green with solid green WiFi light on
You've either no network connection or it's updating. If it doesn't sort it's self out in an hour phone them.
Dave
"The late great Douglas Adams: A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."
  • 5.3K
  • 105
Moderator (Retired) Ty_S
Moderator (Retired)
Hi maccsss
I'm sorry to hear that. I'm unable to locate your account to run some checks so I'll send you a PM and get this looked into.
Speak soon,
Ty
