on 10-08-2022 21:24
Is it possible to have a business virgin media internet 1gb/50 voom and standard 1gb/50 virging fibre at the same address but on two separate accounts?
Thanks for any help.
on 10-08-2022 21:45
Hi @st4v0 ,
thank you for reaching out to us here, welcome to the community.
yes, it is perfectly possible to have two different services on two different accounts at the same property. Although it’s a little bit different to normal it is perfectly possible. I am more than happy to help you achieve what you are looking for if you require any help.
thank you
Jon
on 11-08-2022 00:33
That's great,thanks.
Last question,would this be installed on its own separate line so as to not affect the other network.
on 11-08-2022 05:52
Hi @st4v0,
we could do that if it’s a deal breaker for you but there really is no need most of the time. Installing a second hub will not affect the other in any way provided the incoming signal levels are within specification.
on 11-08-2022 07:10
Im confused,lol
I thought being business internet it would naturally need a seperate line?
So would the line be split by the existing router and then just another router added for the buisiness side?
thanks so far,a great help
on 11-08-2022 07:14
Hi @st4v0
The cable that comes to your property will be split two ways. There will be a separate hub on the end of each split providing the service you pay for. There is generally no need for two cables under the garden.
Think of it a bit like your electricity supply. You don’t need a separate cable to the house for each plug socket you have in your property. Each plug socket can provide you 240 V without a problem. Hope this makes sense.
Jon
on 11-08-2022 09:50
Ok thankyou.
If I do decide to go ahead and have it done would I be able to pm you to start the ball rolling?
on 11-08-2022 10:01
hello again,
Absolutely, no problem at all. I’ve already sent you a private message in case you need my help. Thank you
on 11-08-2022 10:03
One thing not mentioned, if you have two lines coming into your property they will both meet up at the same street cabinet and use all the same infrastructure. so there is not much redundancy.
on 11-08-2022 10:07
Redundancy wasn't so much the problem,I want to run a server and it not be affected if someone's downloading/streaming or playing games on the other hub.
