For the past few weeks I've been getting slow upload speeds. Upstream power levels are 54dBmV
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1 | 39400000 | 54 | 5120 | 64 qam | 4 |
2 | 46200000 | 54 | 5120 | 64 qam | 3 |
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
I have two splitters before the modem but even when I take them off and move the modem closer to the entry point for the cable everything is still the same.
There's also a high number of post RS Errors but I don't know if that's causing an issue. The only trouble I have with downloads is they can take a few minutes to reach full speed.
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1 | 387000000 | 1.2 | 40 | 256 qam | 32 |
2 | 219000000 | 1.9 | 40 | 256 qam | 11 |
3 | 227000000 | 1.7 | 40 | 256 qam | 12 |
4 | 235000000 | 1.7 | 40 | 256 qam | 13 |
5 | 243000000 | 1.5 | 40 | 256 qam | 14 |
6 | 251000000 | 1.5 | 40 | 256 qam | 15 |
7 | 259000000 | 1.5 | 40 | 256 qam | 16 |
8 | 267000000 | 1.4 | 40 | 256 qam | 17 |
9 | 275000000 | 1.5 | 40 | 256 qam | 18 |
10 | 283000000 | 1.5 | 40 | 256 qam | 19 |
11 | 291000000 | 1.5 | 40 | 256 qam | 20 |
12 | 299000000 | 1.7 | 40 | 256 qam | 21 |
13 | 307000000 | 1.5 | 40 | 256 qam | 22 |
14 | 315000000 | 1.2 | 40 | 256 qam | 23 |
15 | 323000000 | 1.2 | 40 | 256 qam | 24 |
16 | 331000000 | 1.2 | 40 | 256 qam | 25 |
17 | 339000000 | 1.2 | 40 | 256 qam | 26 |
18 | 347000000 | 1.2 | 40 | 256 qam | 27 |
19 | 355000000 | 1.2 | 40 | 256 qam | 28 |
20 | 363000000 | 1.2 | 40 | 256 qam | 29 |
21 | 371000000 | 1.2 | 40 | 256 qam | 30 |
22 | 379000000 | 1.2 | 40 | 256 qam | 31 |
23 | 395000000 | 1 | 40 | 256 qam | 33 |
24 | 403000000 | 1 | 40 | 256 qam | 34 |
1 | Locked | 40.9 | 4873 | 12282 |
2 | Locked | 40.3 | 2828 | 20930 |
3 | Locked | 40.3 | 3125 | 20622 |
4 | Locked | 40.9 | 2866 | 20060 |
5 | Locked | 40.3 | 3150 | 18872 |
6 | Locked | 40.9 | 2622 | 20754 |
7 | Locked | 40.9 | 2785 | 21805 |
8 | Locked | 40.9 | 3116 | 17409 |
9 | Locked | 40.9 | 3428 | 23022 |
10 | Locked | 40.9 | 3958 | 18233 |
11 | Locked | 40.9 | 4298 | 17146 |
12 | Locked | 40.3 | 3979 | 15391 |
13 | Locked | 40.9 | 5871 | 28179 |
14 | Locked | 40.9 | 5852 | 35110 |
15 | Locked | 40.9 | 6838 | 26721 |
16 | Locked | 40.3 | 7130 | 34261 |
17 | Locked | 40.3 | 5859 | 24251 |
18 | Locked | 40.3 | 8329 | 33898 |
19 | Locked | 40.9 | 9024 | 31477 |
20 | Locked | 40.3 | 9467 | 12739 |
21 | Locked | 40.9 | 10408 | 22188 |
22 | Locked | 40.3 | 11490 | 28307 |
23 | Locked | 40.3 | 4759 | 12259 |
24 | Locked | 40.3 | 11145 | 28816 |
It's not always been like this and I don't know if I'm just seeing a cause that isn't there, but a few weeks ago there was a power cut which affected the cabinet closest to me and we had no service for hours. That may be when this started or I could just be misremembering dates.
Could that power cut have affected something in the cab causing the high upstream levels?
