Your power levels are way too high and your SNR is a bit on the high side as well. Have you checked for any ongoing issues in your area? If no issues in your area you will need an engineers visit to put these right. Best to ring VM on or just after 8am or alternatively you can wait here for a Virgin staff member to pick it up, typically between 5-10 days, sometimes sooner, sometimes later depending on how busy they are.
Try not to bump the thread as this will throw you further down the list
