4 weeks ago - last edited 4 weeks ago
I keep getting ping spikes over 244ms randomly.
My hub stats have been checked and they are good.
Is it possible is a neighbour is connected to your line that it can cause latency issues?
hub stats
3.0 Downstream channels
1 | 370000000 | 8.9 | 38 | QAM 256 | 2 |
2 | 362000000 | 9.3 | 39 | QAM 256 | 1 |
3 | 378000000 | 8.4 | 39 | QAM 256 | 3 |
4 | 386000000 | 8 | 38 | QAM 256 | 4 |
5 | 394000000 | 7.9 | 38 | QAM 256 | 5 |
6 | 402000000 | 7.8 | 38 | QAM 256 | 6 |
7 | 410000000 | 7.8 | 39 | QAM 256 | 7 |
8 | 418000000 | 7.7 | 39 | QAM 256 | 8 |
9 | 426000000 | 7.6 | 39 | QAM 256 | 9 |
10 | 434000000 | 7.5 | 38 | QAM 256 | 10 |
11 | 442000000 | 7.4 | 39 | QAM 256 | 11 |
12 | 450000000 | 7.5 | 39 | QAM 256 | 12 |
13 | 458000000 | 7.3 | 39 | QAM 256 | 13 |
14 | 466000000 | 7.2 | 39 | QAM 256 | 14 |
15 | 474000000 | 7.1 | 39 | QAM 256 | 15 |
16 | 482000000 | 7 | 39 | QAM 256 | 16 |
17 | 490000000 | 6.9 | 39 | QAM 256 | 17 |
18 | 498000000 | 6.7 | 39 | QAM 256 | 18 |
19 | 506000000 | 6.5 | 39 | QAM 256 | 19 |
20 | 514000000 | 6.6 | 39 | QAM 256 | 20 |
21 | 522000000 | 6.5 | 39 | QAM 256 | 21 |
22 | 530000000 | 6.5 | 39 | QAM 256 | 22 |
23 | 538000000 | 6.5 | 39 | QAM 256 | 23 |
24 | 546000000 | 6.4 | 39 | QAM 256 | 24 |
25 | 554000000 | 6.4 | 39 | QAM 256 | 25 |
26 | 562000000 | 6.3 | 39 | QAM 256 | 26 |
27 | 570000000 | 6.5 | 39 | QAM 256 | 27 |
28 | 578000000 | 6.3 | 39 | QAM 256 | 28 |
29 | 586000000 | 6.2 | 39 | QAM 256 | 29 |
30 | 594000000 | 6 | 39 | QAM 256 | 30 |
31 | 602000000 | 6 | 39 | QAM 256 | 31 |
Answered! Go to Answer
2 weeks ago
The lines to you and your neighbours are connected together in the street cabinet.
Having said that your service is generally good according to the BQM. Many people get spikes like that very frequently at busy times. I doubt that you would get much support from VM.
4 weeks ago
The cause if your not causing it by downloading or uploading is people in your area are uploading causing ping spike
4 weeks ago
Do you still get those spikes when there is no user active on your own connection?
yes even when theres no one on the connection it happens, and it is random when the ping spikes over 200ms, but happens almost everyday atleast a few times or once, and lasts only a few seconds. I game on ethernet, and I tried changing the ethernet cables no difference.
4 weeks ago
Post a link here to your live BQM.
4 weeks ago
4 weeks ago
If you're sure there is no other user on your Hub it does suggest one of your neighbours is hitting the upstream. Do these spikes happen at the same time every day?
4 weeks ago
Im not sure, I will keep the monitor running and post again in 24 hours?
3 weeks ago
heres another test i left it running
3 weeks ago - last edited 3 weeks ago
So a regular spike every 12 hours. VM do run some automated tests, but I've not seen this one before. If you have nothing running at home that might be updating regularly (heating controls etc) then you have a neighbour doing something similar.
