on 27-12-2022 12:45
Hi I am with VM for over a year now and I am getting constant disconnections on my 1Gb broadband - both wired and wireless. Its getting to the point where playing online games is impossible not to mention that this poor service negatively affects our working from home as myself, my son and my wife getting regular disconnections during the google meets, teams and so on.
Hub data below - I will also paste BQM graphs as these are showing regular packet losses. Can anyone look at these and let me know if there is anything of concern from the data and graphs pasted?
Cable Modem Status Item Status Comments Channel Overview Downstream Upstream
Cable Modem Status | Online | DOCSIS 3.1 |
Primary downstream channel | Locked | SC-QAM |
DOCSIS 3.0 channels | 31 | 5 |
DOCSIS 3.1 channels | 1 | 1 |
on 11-02-2023 10:12
Thanks for coming back to us buchosmambo, have you had any further issues since you last posted or any improvements with your connection?
Kind Regards,
Steven_L
on 12-02-2023 20:37
@Steven_L yes I do. Constant high spikes causing disconnection. Its time you look into your end of things
on 14-02-2023 20:58
Hi buchosmambo
Thanks for coming back to us. We've ran a check here and no issues are showing. All the levels are in spec, no issues with SNR or congestion.
Can you post your Hub status and logs? How to do this;
• Copy/paste the data from each of the tabs as text into a 'REPLY' as opposed to 'QUICK REPLY'. Please do not include your MAC address.
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc - You can do this at https://www.thinkbroadband.com/broadband/monitoring/quality
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum 🙂
on 15-02-2023 09:29
1 | 411000000 | 4.2 | 37 | QAM 256 | 1 |
2 | 419000000 | 4.5 | 38 | QAM 256 | 2 |
3 | 427000000 | 4.7 | 38 | QAM 256 | 3 |
4 | 435000000 | 4.9 | 38 | QAM 256 | 4 |
5 | 443000000 | 4.8 | 38 | QAM 256 | 5 |
6 | 451000000 | 5.2 | 38 | QAM 256 | 6 |
7 | 459000000 | 5.1 | 38 | QAM 256 | 7 |
8 | 467000000 | 5.1 | 38 | QAM 256 | 8 |
9 | 475000000 | 5 | 38 | QAM 256 | 9 |
10 | 483000000 | 5.1 | 38 | QAM 256 | 10 |
11 | 491000000 | 5.4 | 38 | QAM 256 | 11 |
12 | 499000000 | 5.4 | 38 | QAM 256 | 12 |
13 | 507000000 | 5.4 | 38 | QAM 256 | 13 |
14 | 515000000 | 5.3 | 38 | QAM 256 | 14 |
15 | 523000000 | 5.5 | 38 | QAM 256 | 15 |
16 | 531000000 | 5.9 | 38 | QAM 256 | 16 |
17 | 539000000 | 6.2 | 38 | QAM 256 | 17 |
18 | 547000000 | 6.3 | 38 | QAM 256 | 18 |
19 | 555000000 | 6.4 | 38 | QAM 256 | 19 |
20 | 563000000 | 6.4 | 38 | QAM 256 | 20 |
21 | 571000000 | 6.5 | 38 | QAM 256 | 21 |
22 | 579000000 | 6.4 | 38 | QAM 256 | 22 |
23 | 587000000 | 6.4 | 38 | QAM 256 | 23 |
24 | 595000000 | 6.1 | 38 | QAM 256 | 24 |
25 | 603000000 | 6 | 38 | QAM 256 | 25 |
26 | 611000000 | 5.6 | 38 | QAM 256 | 26 |
27 | 619000000 | 5.1 | 38 | QAM 256 | 27 |
28 | 627000000 | 4.8 | 38 | QAM 256 | 28 |
29 | 635000000 | 4.8 | 38 | QAM 256 | 29 |
30 | 643000000 | 4.9 | 38 | QAM 256 | 30 |
31 | 651000000 | 4.7 | 38 | QAM 256 | 31 |
1 | Locked | 37 | 209 | 0 |
2 | Locked | 38 | 197 | 0 |
3 | Locked | 38 | 191 | 0 |
4 | Locked | 38 | 171 | 0 |
5 | Locked | 38 | 207 | 0 |
6 | Locked | 38 | 391 | 0 |
7 | Locked | 38 | 1108 | 0 |
8 | Locked | 38 | 1974 | 1 |
9 | Locked | 38 | 2036 | 1 |
10 | Locked | 38 | 1224 | 0 |
11 | Locked | 38 | 632 | 0 |
12 | Locked | 38 | 369 | 0 |
13 | Locked | 38 | 242 | 0 |
14 | Locked | 38 | 187 | 0 |
15 | Locked | 38 | 171 | 0 |
16 | Locked | 38 | 146 | 0 |
17 | Locked | 38 | 129 | 0 |
18 | Locked | 38 | 122 | 0 |
19 | Locked | 38 | 132 | 0 |
20 | Locked | 38 | 145 | 0 |
21 | Locked | 38 | 147 | 0 |
22 | Locked | 38 | 147 | 0 |
23 | Locked | 38 | 133 | 0 |
24 | Locked | 38 | 136 | 0 |
25 | Locked | 38 | 125 | 0 |
26 | Locked | 38 | 123 | 0 |
27 | Locked | 38 | 150 | 0 |
28 | Locked | 38 | 155 | 0 |
29 | Locked | 38 | 144 | 0 |
30 | Locked | 38 | 141 | 0 |
31 | Locked | 38 | 167 | 0 |
on 15-02-2023 09:29
0 | 49600000 | 38.8 | 5120 | QAM 64 | 9 |
1 | 43100000 | 37.8 | 5120 | QAM 64 | 10 |
2 | 36600000 | 37.3 | 5120 | QAM 64 | 11 |
3 | 30100000 | 36.3 | 5120 | QAM 64 | 12 |
4 | 23600000 | 36.3 | 5120 | QAM 64 | 13 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
on 15-02-2023 09:30
15-02-2023 08:44:09 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-02-2023 08:44:09 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-02-2023 21:18:42 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-02-2023 21:18:42 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-02-2023 20:13:18 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-02-2023 20:13:18 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-02-2023 20:10:12 | error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-02-2023 22:02:25 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-02-2023 22:02:25 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-02-2023 21:00:24 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-02-2023 21:00:24 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 12 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-02-2023 20:00:02 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-02-2023 20:00:02 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-02-2023 08:10:10 | error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-02-2023 02:02:44 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-02-2023 02:02:44 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-02-2023 01:52:38 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-02-2023 01:52:38 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-02-2023 12:56:29 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-02-2023 12:56:29 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-02-2023 12:46:23 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-02-2023 12:46:23 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-02-2023 00:10:27 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-02-2023 00:10:27 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-02-2023 23:01:02 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-02-2023 23:01:02 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-02-2023 12:54:21 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-02-2023 12:54:21 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-02-2023 12:34:06 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-02-2023 12:34:06 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-02-2023 03:40:12 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-02-2023 03:40:12 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 15-02-2023 09:35
All stats above - below is my latest BQM and this is very interesting as clearly between bang on midnight and 8 am there is a significant drop in max latency (yellow) but even then I get these random spikes. This trend can be seen every day where max latency drops to very low levels between midnight and 8 am - thats where online gaming is the best as PING is very low. Other than that I get very high ping and random disconnections whenever that high yellow spike happens...on WIRED connection....
on 17-02-2023 16:36
Hi @buchosmambo 👋,
Thank you for your post and I am sorry you are still having these, issues. I have taken a look at our systems and can see there are no issues outstanding on what this can be, your power levels look fine and your connection to devices looks good also. Looking at SamKnows I cannot see any dropouts for the past week so far. I can see you have not rebooted your hub in over 20 days, could you reboot for me and monitor this to see if this improves?
Keep us posted 😊
Zoie
on 17-02-2023 17:25
Thanks for reply but I am not keen on resetting this HUB as unlike previous Hub 4 - this Hub 5 takes approx 40m to establish connection and get all the devices fully connected - plus extra few hours for PODs to fully reconnect.
I would like to understand what is it that you are testing remotely? Is it HUB status? Connection between cabinet and my property i.e. your HUB? or a full End to End connection?
on 19-02-2023 17:59
Hi buchosmambo, thanks for the message and welcome back to the forums.
I have checked the area and cannot see any outages in the area.
I can confirm that there has been no drops since you have posted,
Can you confirm how the service is at the moment?
Kind regards, Chris.
