NikM
Message 11 of 13
Re: Help with choosing a Router?
 We've currently got 4 AP's - one on each floor. All of our network gear is in the basement in a server cupboard , so the WiFi from the router itself generally doesn't reach the ground floor.
Historically, even in the basement we've generally logged into the AP instead of directly to the router.
The rest of the house has a fair bit of structural steel which tends to block mobile phone signals  hence the need for an AP on each floor.
Can I just check - when I switch the Super hub 3 to modem mode, will I be able to still connect directly to it wirelessly whilst in the basement?
Thanks.
NikM
  • 489
  • 26
  • 102
tonycv51
Fibre optic
Message 12 of 13
No wireless on the Hub when in modem mode - not sure it that means another AP in the basement sorry...
NikM
Message 13 of 13
Okay thanks, I will try the new router first and see if the existing AP's start working better!
NikM
