Just joined
Help...no connection hub 3
Hello,
I have installed a new hub 3 and I am not getting any internet WiFi or by ethernet...
I have logged in and it states my wireless is on but it says Internet (access denied) I have tried factory resetting to no avail.
The lights are fine.
I am to connect to the router, follow the set up instructions and log in, I tried using the network diagnostic tool and and found the following
Red explanation mark: board band services
Green ethernet connection
Red explanation mark: checking WiFi connections
Any suggestions? Any help would be appreciated
  • 25.03K
  • 1.44K
  • 3.19K
Re: Help...no connection hub 3
Have you called the automated number to activate the new equipment?
  • 23
  • 6
  • 7
It sounds like your hub hasn't been activated properly. PM me your account number and the hub serial number and I should be able to sort it for you.
