on 21-01-2023 15:38
Hi Team,
I have a hub3 years ago with VM. Recently it started showing internet connection issues even with full wifi signals. This happens in three mobiles with different makers.
I have reboot many times, almost daily, after online trouble shootings. It works fine for short time and then internet connection lost again.
I have been trying to contact VM before Xmas and still no solution. I had to file a complaint which directed me to phone 150. 150 gave me link as text which suggested reboot hub. A good circle without a solution.
please help to save me from rebooting the hub.
GJ
on 21-01-2023 15:46
Our Hub 3 WiFi is more stable with the Channels set to Manual and Disable Channel Optimization ( ticked )
The settings look like this ...
on 21-01-2023 15:58
Thanks for your quick reply. I will try your solution next.
on 23-01-2023 19:00
Hi @gm2007, thanks for posting and welcome back to our community.
Sorry to hear you've been having some connection issues. And I'm sorry for any inconvenience this may be causing you. I would like to take a closer look on your behalf. I am going to send you a private message. Please look out for the purple envelope in the top right of your screen.
Lee_R
on 23-01-2023 20:54
on 26-01-2023 09:17
Hi gm2007, thanks for the message. I have looked over this and cannot see any issues which would be affecting you.
Can you create a broadband quality monitor here to monitor the connection.
Kind regards, Chris.
on 27-01-2023 23:15
on 27-01-2023 23:18
on 27-01-2023 23:27
<a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/5bf24c2e5133ba2f3eba38fb9a00f1dfbe9d2ee1-27-01-2023"><img alt="My Broadband Ping - My VM broadband connection" src="https://www.thinkbroadband.com/broadband/monitoring/quality/share/5bf24c2e5133ba2f3eba38fb9a00f1dfbe9d2ee1-27-01-2023.png" /></a>
my wifi speed test result for download speed was:
66, 3, 0.86,89 and 95 MB/s for last several days. The was tested by APP Network Analyser on mobile.
Upload speed was about 26 Mb/s.
27-01-2023 23:33 - edited 27-01-2023 23:33
Ask for a new hub or use modem mode and get a better wifi router with 1Gb ports
