on 09-06-2022 02:25
Help!
Broadband went offline for around 20 minutes. Website is not recording a fault, no error logs reported on the router. Tried network checkup but it didn't get past 7% before cutting off. No warning whatsoever of the outage.
I've lost SR in competitive due to this. How do I get this back?
What caused this? Please help.
on 09-06-2022 13:49
on 09-06-2022 19:40
Clearly you have never worked in networking before - These things do not just happen.There is always a cause, I have a near new router. Outages like this should not just happen, as promised previously. We need to work out the rootcause and ensure it doesn't occur again.
SR is related to competitive ranking on games.
on 09-06-2022 19:48
I’ve worked with large networks for years and problem happen, it’s a fact of life. Users change their equipment their self, use non VM coax, leave connections unterminated, cars hit street boxes, other utilities dig up VM cables, it goes on and on. You just have to live with it.
on 09-06-2022 19:59
By all means, feel free to live with an inferior flappy connection. I intend to get what I pay for.
10-06-2022 14:10 - edited 10-06-2022 14:12
Well when these things happened to me... a United Utilities Engineer (sic) had cut through the VM cable whilst laying a water pipe. They also disconnect customers when they are resegmenting the network - or similar. Usually in the wee small hours to minimise customer disruption if possible. Or if they have to move your connection in the street cab to accommodate other customers it will be a short disconnect.
There is no Service Level Agreement on our residential packages - you need to be on a Business package for that (dunno how much use it will be though) - so small breaks like this will not be covered.
If you want compensation then see these for a starter...
https://www.virginmedia.com/help/automatic-compensation
https://store.virginmedia.com/the-legal-stuff/terms-and-conditions-for-fibre-optic-services/automati...
on 12-06-2022 14:52
Good Afternoon @bubbleshoot, thanks for your post on our Community Forums, and I'm sorry to hear of the recent unexpected drop in connection!
Can you please advise me if there have been any further issues, or even if this is still ongoing?
I've been able to look into the local area and currently cannot see any faults recognised.
Kindest regards,
David_Bn
on 14-06-2022 00:07
Hi david,
It has just occurred again tonight. There is nothing more I can do other than use my own hotspot which at present is more reliable.
The internet went off for around 5 minutes and then came back on. I have tried to check if VM was down but the website is again under maintenance.
on 14-06-2022 00:16
Hi @bubbleshoot
The website is up and running again now.
Apart from the Check service status at the top of the page which usually only identifies large scale dropouts you could also try the automated Service Status number 0800 561 0061. This often gives details of more local issues down to postcode level.
on 14-06-2022 00:26
Is there any way we can stablise this connection to stop it from happening again?
