on 10-06-2023 01:01
Whenever I connect any device to VM Wifi and use Netflix it says I'm uisng a VPN, which I'm not as far as I can tell. When the same device connects to Netflix through mobile data, Netflix works fine.
Can anyone advise how I can fix this problem?
on 10-06-2023 07:47
Talk to Netflix tell them your IP has changed and that you need it unblocked or you cancel VM can't do anything.
