on 13-05-2023 14:53
Having problems to order a WiFi Pods
I’m under Volt package
done with the scan found blackspot
there’s no option from the app , did contact customer service, there’s always with error to place the Pods order
on 13-05-2023 21:28
Hi @joint
The pods are free if you are on the Gig1 speed, or on one of the Volt packages, otherwise they are £8 a month.
Please see this message from the <<< pinned post >>> for help in ordering the wifi pods
You need to use the Connect app to perform the Home Scan in the area where the signal is low(est)
The info below is a copy paste of the steps provided by @John_GS (Forum Team)
Please can you try the below steps for me on the app as it should help sort this;
on 13-05-2023 23:26
Hi Newapollo
thx for your reply
I had did research from the forum, totally did what you advise,
Did found a room with blackspot , download speed average 3Mbps - 11 Mbps
After scanning there’s no option for me to Optimise WiFi or order a Pods , I had try to Optimise manually then did a scan the problem stay still , totally dead end
Had made a live chat & phone call to VM , every time they said the Pods order was placed, but end up will be telling there is a error for the order to be placed it doesn’t gone through, have dealing with this issue about a week sine my Volt package actived , day by day calling & live chat & WhatsApp chat, hours & hours waiting ……
on 16-05-2023 08:49
Hi @joint thanks for your post here in the Community, although we're sorry to hear of the concerns you've raised here regarding not being able to order a WiFi Pod.
It does however seem that since your post here, you've been able to get the support you need on this though via other means.
If you do need any further help beyond this though, please let us know and we'll do our best to help!
Many thanks
