on 06-06-2022 14:48
Installed the new HUB5 this morning. It appears to be working but I have a permanent flashing green light. According to the documentation the hub is downloading and updating.
I find it hard to believe it would be doing this for several hours.
Any ideas or thoughts anyone?
Bill
Answered! Go to Answer
on 09-06-2022 14:48
I had the same problem with my Hub 5 a while back. In my case I did I pin hole reset and reset it back to modem mode and green light was solid. Maybe a problem with the hub not resetting itself after a update but who knows with some of the problems some others have been having with the Hub5.
on 09-06-2022 13:03
Update - green light has now been flashing on the HUB5 for three days. Everything appears to be working.
Bill
on 09-06-2022 14:47
HI @BillBudd, thanks for posting and welcome back to our community.
Sorry to hear that you're having concerns with the flashing light on your hub 5. We've had a look at our systems from here and cannot find anything that explains the issues you're having. I am going to send you a private message. Please look out for the purple envelope in the top right of the screen.
Lee
on 09-06-2022 14:48
on 09-06-2022 20:38
on 10-06-2022 11:16
Hi BillBudd, thanks for getting back to me privately.
This is just a quick note to confirm you're satisfied with the response and efforts of the forum team? Remember, if you ever need assistance in the future, our fantastic community and forum team are always willing to lend a hand.
Lee_R
on 10-06-2022 11:47
Yes, very grateful for help received.
