on 20-12-2021 13:09
I want to use an alternative DNS provider, in my case a Pi-Hole but I want it network wide.
If I disable DHCP and allow my Pi-Hole to do DHCP, all is good on the main network but the guest network collapses. I need the guest network.
Any suggestions or advice welcome.
Thank you
on 20-12-2021 13:26
You cant change the DNS on any VM hubs.
on 20-12-2021 13:36
on 20-12-2021 15:03
How have you setup your Pi-Hole? The whole idea of a guest network is that it has NO connection to your main network, but your are expecting the guest network to be able to access your Pi-Hole. I can be done with your own router and using VLANs, but just using a VM hub in router mode, I don’t see how you can achieve what you want.
