  • 7
Message 1 of 12
HUB4 Constant wifi dropping
Since installing the new HUB4 on Monday I am regularly losing the connection to wifi, which is extrmely disruptive when working from home as I am being kicked out of teams meetings all the time. This happens between 5-10 times a day and is becoming really annoying. This is not great at all. I have tried to go back to my original router but that wont seem to work at all now. Please help!!!
  • 12.27K
  • 950
  • 1.57K
Message 2 of 12
Re: HUB4 Constant wifi dropping
What is your connection like using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
  • 25.14K
  • 1.44K
  • 3.2K
Message 3 of 12
Just wireless connections?
Have you tried running wired instead?
  • 7
Message 4 of 12
I am on wifi, the hub is in the living room, but my office is upstairs, so option not there to work on direct connection. It was perfectly fine on wifi on my HUB 3
  • 7
Message 5 of 12
Wired is not an option, office upstairs, hub downstairs. didnt have this with hub 3
  • 14.81K
  • 622
  • 1.43K
Message 6 of 12
Try getting your own wireless router with 1Gb ports and put hub in modem mode.
  • 7
Message 7 of 12
Why? I pay VM for my service, it should work
  • 25.14K
  • 1.44K
  • 3.2K
Message 8 of 12
Then you'll need a mesh system or your own better router.
  • 25.14K
  • 1.44K
  • 3.2K
Message 9 of 12
You don’t pay for WiFi connectivity. You pay for the speed/connection to be delivered to your home. How you connect and optimise devices internally is down to you to sort.
  • 7
Message 10 of 12
I pay for the hub which provides the wifi capability
