on 17-01-2022 12:43
Replaced faulty Hub 2 with new HUB 3 bjut this, from square one, shows permanent RED light at base indicating overheat? Performed all diagnostics from the Virgin site including factory reset but with no change
Do I require a replacement HUB if only for safety reassurance?
on 17-01-2022 16:48
on 17-01-2022 17:32
Hi @SandyMacD
Welcome to our Community Help Forum 🙂
Thank you for making your first post regarding the red light on your Hub 3, are you using your Hub in Modem Mode?
I would like to arrange an engineer visit for you, if you Hub is overheating then our engineer will replace your faulty Hub on the spot. I shall send you a private message now to obtain the details required.
Best wishes,
Serena
on 18-01-2022 09:11
Serena
Many thanks
For some reason, your private message is hiding from me this morning
Could you possibly try again and i will respond with the required details
Apologies
Sandy
on 18-01-2022 09:47
Thanks for response
The kit works perfectly with 4 devices on WiFi and one via ehternet cable!!
Only snag is constant warning light
You will see here that Serena has the problem in hand
Sandy MacD
on 21-01-2022 18:06
Thanks for coming back to us @SandyMacD.
Serena is offline at the moment, I will send over a private message right now and we can get started.
Regards,
Steven_L
