  • 139
  • 12
  • 47
Compbck
Superfast
HUB Access Code
Is it possible to change the HUB Access Code (not to be confused with the wifi passphrase)
  • 3.06K
  • 170
  • 490
chenks
Wise owl
Re: HUB Access Code
what do you mean by "access code"?
do you mean the admin password to log in to the hub?
if yes, then yes you can change that admin password.
