on 18-12-2021 18:10
A couple of weeks ago I upgraded from the SuperHub 3 to the HUB 5.
I've had constant drop outs, many times every day. The main household PC is connected via ethernet cable and other devices are either ethernet or wifi. The hub has been rebooted and reset several times to no avail. Running diagnostics doesn't reveal any clues as apparantly "everything's fine". The light on the hub stays white. Somtimes it fades white, but no other lights are seen.
Service status comes back that everything is fine with the broadband, and all the connections are tight.
Help.
Answered! Go to Answer
on 21-12-2021 13:34
Hi @jacamanda,
Thank you for coming back to me via Private Message. As discussed, I have been able to book in the first available appointment for the technician to visit.
Please keep us updated on how your appointment goes and let us know if there's anything else we can do to help in the meantime.
You can also keep an eye on your appointment via your online account if needed.
Let us know how you get on.
Thank you. 🙂
on 18-12-2021 18:11
Channel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID1 | 339000000 | 10.2 | 42 | QAM 256 | 26 |
2 | 139000000 | 7.3 | 40 | QAM 256 | 1 |
3 | 147000000 | 7.5 | 40 | QAM 256 | 2 |
4 | 155000000 | 7.4 | 40 | QAM 256 | 3 |
5 | 163000000 | 7.3 | 40 | QAM 256 | 4 |
6 | 171000000 | 7 | 40 | QAM 256 | 5 |
7 | 179000000 | 7.1 | 40 | QAM 256 | 6 |
8 | 187000000 | 7.4 | 40 | QAM 256 | 7 |
9 | 195000000 | 7.7 | 40 | QAM 256 | 8 |
10 | 203000000 | 7.8 | 40 | QAM 256 | 9 |
11 | 211000000 | 7.9 | 40 | QAM 256 | 10 |
12 | 219000000 | 8 | 40 | QAM 256 | 11 |
13 | 227000000 | 7.9 | 39 | QAM 256 | 12 |
14 | 235000000 | 7.7 | 39 | QAM 256 | 13 |
15 | 243000000 | 7.3 | 39 | QAM 256 | 14 |
16 | 251000000 | 7.3 | 40 | QAM 256 | 15 |
17 | 259000000 | 7.6 | 40 | QAM 256 | 16 |
18 | 267000000 | 7.9 | 41 | QAM 256 | 17 |
19 | 275000000 | 8.2 | 41 | QAM 256 | 18 |
20 | 283000000 | 8.8 | 41 | QAM 256 | 19 |
21 | 291000000 | 9.2 | 41 | QAM 256 | 20 |
22 | 299000000 | 9.4 | 41 | QAM 256 | 21 |
23 | 307000000 | 9.6 | 42 | QAM 256 | 22 |
24 | 315000000 | 9.8 | 42 | QAM 256 | 23 |
25 | 323000000 | 9.8 | 42 | QAM 256 | 24 |
26 | 331000000 | 9.9 | 42 | QAM 256 | 25 |
27 | 347000000 | 10.4 | 42 | QAM 256 | 27 |
28 | 355000000 | 10.4 | 42 | QAM 256 | 28 |
29 | 363000000 | 10.2 | 42 | QAM 256 | 29 |
30 | 371000000 | 9.6 | 42 | QAM 256 | 30 |
31 | 379000000 | 9.2 | 42 | QAM 256 | 31 |
Channel Locked Status RxMER (dB) Pre RS Errors Post RS Errors1 | Locked | 42 | 0 | 0 |
2 | Locked | 40 | 0 | 2 |
3 | Locked | 40 | 0 | 0 |
4 | Locked | 40 | 0 | 0 |
5 | Locked | 40 | 0 | 0 |
6 | Locked | 40 | 0 | 2 |
7 | Locked | 40 | 0 | 10 |
8 | Locked | 40 | 0 | 0 |
9 | Locked | 40 | 0 | 0 |
10 | Locked | 40 | 0 | 0 |
11 | Locked | 40 | 0 | 0 |
12 | Locked | 40 | 0 | 0 |
13 | Locked | 39 | 0 | 0 |
14 | Locked | 39 | 0 | 0 |
15 | Locked | 39 | 0 | 6 |
16 | Locked | 40 | 0 | 11 |
17 | Locked | 40 | 0 | 0 |
18 | Locked | 41 | 0 | 2 |
19 | Locked | 41 | 0 | 0 |
20 | Locked | 41 | 0 | 0 |
21 | Locked | 41 | 0 | 0 |
22 | Locked | 41 | 0 | 0 |
23 | Locked | 42 | 0 | 0 |
24 | Locked | 42 | 0 | 0 |
25 | Locked | 42 | 0 | 0 |
26 | Locked | 42 | 0 | 0 |
27 | Locked | 42 | 0 | 2 |
28 | Locked | 42 | 0 | 0 |
29 | Locked | 42 | 0 | 0 |
30 | Locked | 42 | 0 | 0 |
31 | Locked | 42 | 0 | 0 |
on 18-12-2021 18:12
Channel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID1 | 60300000 | 46.5 | 5120 | QAM 64 | 1 |
2 | 53700000 | 46 | 5120 | QAM 64 | 2 |
3 | 46200000 | 45 | 5120 | QAM 64 | 3 |
4 | 39400000 | 44 | 5120 | QAM 64 | 4 |
Channel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 18-12-2021 18:13
General Configuration
Network accessMaximum Number of CPEsBaseline PrivacyDOCSIS ModeConfig fileAllowed |
1 |
Enabled |
3.1 |
ncxv9873254k;fg87dsfd;kfo |
SFIDMax Traffic RateMax Traffic BurstMin Traffic Rate27672 |
230000061 bps |
42600 bytes |
0 bps |
Primary Upstream Service Flow
SFIDMax Traffic RateMax Traffic BurstMin Traffic RateMax Concatenated BurstScheduling Type27671 |
22000061 bps |
42600 bytes |
0 bps |
42600 bytes |
Best Effort |
on 18-12-2021 18:13
Time Priority Description18-12-2021 18:05:12 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-12-2021 18:05:12 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: 1 2; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-12-2021 18:05:08 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
18-12-2021 18:05:03 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-12-2021 18:05:03 | warning | Dynamic Range Window violation |
18-12-2021 18:05:02 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-12-2021 18:04:57 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-12-2021 18:04:53 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-12-2021 18:04:51 | notice | Honoring MDD; IP provisioning mode = IPv4 |
18-12-2021 18:04:48 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-12-2021 18:04:42 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-12-2021 11:07:22 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 18-12-2021 19:36
Power levels are too high on 4 downstream channels and you have Post RS errors that are uncorrectable. You probably need a technician’s visit, call:
Check with Area faults on www.virginmedia.com/servicechecker or 0800 561 0061 If you have a VM landline 150 The phone goes down to post code level.
If no faults found:
Call Customer Services on 0345 454 1111/150 if you have a VM landline or wait a day or two for a VM staff member to get to your post.
on 20-12-2021 20:46
Hi @jacamanda,
Welcome to our Community Forums! Thank you for your first post, and I'm sorry to hear that you're experiencing some ongoing connection issues with your Hub 5!
I've had some issues locating your account, but I'll be more than happy to look into this further for you via Private Message. Please keep an eye out for a purple envelope at the top right corner. I will be in touch soon.
Thank you.
on 21-12-2021 13:34
Hi @jacamanda,
Thank you. 🙂
on 21-12-2021 13:39
Thank you. Looking forward to getting back online. 😊
21-12-2021 13:55 - edited 21-12-2021 13:56
@jacamanda wrote:Thank you. Looking forward to getting back online. 😊
Also bear in mind the Hub 5 is still in trials and there are a few bugs in the Firmware.
