on 04-10-2021 18:54
I recently set up my new Hub 4 - all wifi equipment working fine apart from my laptop which will not connect to the internet via the new router, I've tried the usual router/computer reboot fix on a number of occassions without success - I am managing with an ethernet cable but for work I normally use the laptop in a different area from the router which is causing major problems, plus my wireless printer no longer works. Also the router is running rather warm, something my hub 3 did not do - is that normal
on 10-10-2021 13:32
Thanks for the reply Zach - all our devices are working fine apart from my laptop which will either only connect to WIFI for 30 seconds then drops out or will not connect at all.
Previous to connecting to the HUB4 my laptop WIFI connection was perfect anywhere in my house, now I'm stuck in a bedroom at the end of an Ethernet cable (which thankfully does connect perfectly)
Dave
on 12-10-2021 13:35
Hi @dwsumme
Thanks for posting on our community forum!
Do you have other devices which connect to WiFi perfectly?
