Message 1 of 8
HUB 4 keeps losin connection with SKY box
Absolutely sick of trying to get through to someone in virgin media who can deal with this and not get fobbed off.  Since getting this new hub4 2 weeks ago it loses connection with our Sky box constantly.   We're having to reconnect every time we turn the TV back on.... anyone know how to get hold of some kind of technical support?
  • 3.81K
  • 608
  • 827
Community elder
Message 2 of 8
Re: HUB 4 keeps losin connection with SKY box
Hi richardsc,
If your hub is close enough to the Sky box then try connecting by ethernet cable.
Is it a Sky Q box? If so try disabling 5GHz on the Sky Q box by going to Settings, then hitting 001 before Enter. This takes you to a hidden menu where you can disable the 5GHz.  I think it's set up on channel 36.
The Sky box transmits it’s own WiFi signal to connect to Mini Boxes and this might be causing some interference, so try using different SSIDs on your hub for the 2.4GHz and 5GHz and also different channels.
You could download and use an app such as  Inssider or Wifi Analyzer app on a smartphone, or tablet, which will show you how congested the 2.4GHz and 5GHz wifi bands are, so you can use that info to change the various channels and get a better overall signal.
Dave
Message 3 of 8
hi thanks for that, not sure I'll be able to do it....sounds a bit technical for me!! but I'll give it a go
Message 4 of 8
Hi again.  If I disable 5ghz and this doesn't work do i just reset? Yes it is sky q box
  • 24.4K
  • 1.4K
  • 3.1K
Message 5 of 8
Resetting a SkyQ box will lose all your recordings etc.
  • 3.81K
  • 608
  • 827
Community elder
Message 6 of 8
Hi again richardsc,
yes just log into the Sky Q settings again as above and re-enable the 5G
Dave
Message 7 of 8
Tried this and its still losing connection.  Other than using ethernet cable anyone know another way around this?
Anonymous
Not applicable
Message 8 of 8
You could try these. https://www.amazon.co.uk/Tenda-PH3-1000Mbps-Powerline-expansion/dp/B0746H97SX/ref=sr_1_2_sspa?dchild...
Plug one into the power socket close to your router/hub and connect the ethernet cable to it. then plug the other one in the power socket closest to your Skybox and connect the ethernet cable to the plug and sky box.
Your internet signal will now run over your houses electrical wiring and this usually gives a much better experience. Let us know if it works 🙂
