on 05-07-2021 10:56
Can anyone help?
I had major problems with my broadband for moths and eventually the whole street was re-wired and new cables and equipment were put in my home which included a nice new Hub 4. The problem is that randomly and anytime there is a power outage or I reset the hub for any reason the SSID I changed for the Hub keeps resetting to it's default settings, and it's driving me mad now.
Any ideas how I can make this permanent?
on 05-07-2021 11:26
on 05-07-2021 11:35
Not a fix but a workaround - could you use the Backup and Reload options (I assume they exist in the SH4) to easily get your settings back?
on 05-07-2021 13:05
I've set that up and I'll let you know how it goes. Thanks
Also backed up, just in case.
on 07-07-2021 11:24
Hi Mazxtc
Let us know if this helps resolve the issue or if you need any further support on this.
Rob
on 08-07-2021 08:08
on 08-07-2021 16:15
Thanks for coming back to us @Mazxtc and please do keep us updated over the next few days with any improvements or issues.
Steven_L
on 09-07-2021 11:47
on 09-07-2021 11:58
@Mazxtc wrote:
<snip>
I'm beginning to think this is not only a virgin bug, but my nice new hub is faulty too as it loses connection several times a week.
You need to setup a BQM here www.thinkbroadband.com/ping
This will monitor your incoming circuit 24 x 7 and let you see any issues in the VM supply. Also post your power levels and network log for comment.
on 09-07-2021 13:44
Thanks for coming back to us @Mazxtc, I would like to take a further look into your account but haven't been unable to do this as I cannot locate your account from your community profile.
I will drop over a private message for you right now to confirm a few details and we can get this looked into further for you. Please look out for my message.
Regards,
Steven_L
