on 14-09-2022 10:37
I'm having a bunch of weird issues.
My devices that connect by wifi keep dropping connections. They'll show me connected to the wifi network but with no internet connection. I have to forget the network and re-join entering the password. Then its fine usually for a day at least.
I have some devices connected by ethernet, these work fine but if I turn my VPN on (PIA), it will work for a few minutes and then won't connect to any sites. If I change my VPNs ports/servers it will again work for a bit and then stop. Not sure if this is related to the above or not.
I've not made any changes to my Wifi/Router/VPN for ages so i'm not sure what's happened to mess everything up.
I've reset my router a few times but it keeps happening,
on 14-09-2022 14:48
on 14-09-2022 15:00
Router mode.
on 14-09-2022 15:03
on 14-09-2022 18:29
Already have it split frequency and optimised switched off. Its not a signal strength issue, I can connect to the wifi but it won't let me access the web unless I disconnect, forget the network and re-join. My TV is about 12 inches from the router and my work laptop is about 5ft away, in the same room direct line of sight.
on 16-09-2022 18:33
Hi there @randybaton
Thank you so much for your post and welcome back to the forums!
We are so sorry to hear that you are facing this issue with your services! I can imagine how frustrating this must be.
Can you post your Hub status and logs? To do this;
• Copy/paste the data from each of the tabs as text into a 'REPLY' as opposed to 'QUICK REPLY'. Please do not include your MAC address.
Also, please set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum.
Thank you.
on 16-09-2022 20:59
on 17-09-2022 07:09
Wasn't my post, but I use powerline extenders to get Ethernet around my house. I have one that's a wifi booster, you can pick up refurbished ones for £30.
I switched off the wifi extender and that seems to have sorted out the issue. I think it might have been something to do with devices swapping between the extender and router. Although my tv is 10cm from my router and about 25ft from the extender so I'm not totally convinced that's why i had to keep entering the network details. I've been using the wifi extender for years and haven't updated it in ages so don't know why it would have started causing an issue. I'll leave it off for a week and see if the issues come back. If it comes back after i switch it back on i'll do a factory reset of the powerline network and extender.
Should the wifi extender be using the same channel as my router? They were on different channels, but I couldn't find anything that said thats a bad thing.
on 17-09-2022 07:22
Acquired Downstream Channel (Hz) | 234750000 | Locked |
Ranged Upstream Channel (Hz) | 46200000 | Locked |
Provisioning State | Online |
1 | 234750000 | 5.6 | 40 | 256 qam | 13 |
2 | 242750000 | 5.8 | 40 | 256 qam | 14 |
3 | 250750000 | 6.1 | 40 | 256 qam | 15 |
4 | 258750000 | 6 | 40 | 256 qam | 16 |
5 | 266750000 | 6.5 | 40 | 256 qam | 17 |
6 | 274750000 | 6 | 40 | 256 qam | 18 |
7 | 282750000 | 6.9 | 40 | 256 qam | 19 |
8 | 290750000 | 6.9 | 40 | 256 qam | 20 |
9 | 298750000 | 7.6 | 40 | 256 qam | 21 |
10 | 306750000 | 7.9 | 40 | 256 qam | 22 |
11 | 314750000 | 8.3 | 40 | 256 qam | 23 |
12 | 322750000 | 9.3 | 40 | 256 qam | 24 |
13 | 330750000 | 9.5 | 40 | 256 qam | 25 |
14 | 338750000 | 10 | 40 | 256 qam | 26 |
15 | 346750000 | 9.1 | 40 | 256 qam | 27 |
16 | 354750000 | 9.5 | 40 | 256 qam | 28 |
17 | 362750000 | 9.1 | 40 | 256 qam | 29 |
18 | 370750000 | 8.9 | 40 | 256 qam | 30 |
19 | 378750000 | 9.1 | 40 | 256 qam | 31 |
20 | 386750000 | 8.5 | 40 | 256 qam | 32 |
21 | 394750000 | 9 | 40 | 256 qam | 34 |
22 | 402750000 | 8.3 | 40 | 256 qam | 35 |
23 | 410750000 | 8.3 | 40 | 256 qam | 36 |
24 | 418750000 | 7.5 | 40 | 256 qam | 37 |
1 | Locked | 40.9 | 114 | 0 |
2 | Locked | 40.3 | 84 | 0 |
3 | Locked | 40.3 | 52 | 0 |
4 | Locked | 40.3 | 66 | 0 |
5 | Locked | 40.9 | 32 | 0 |
6 | Locked | 40.3 | 66 | 0 |
7 | Locked | 40.3 | 62 | 0 |
8 | Locked | 40.9 | 50 | 0 |
9 | Locked | 40.3 | 39 | 0 |
10 | Locked | 40.9 | 29 | 0 |
11 | Locked | 40.3 | 29 | 0 |
12 | Locked | 40.9 | 64 | 0 |
13 | Locked | 40.3 | 45 | 0 |
14 | Locked | 40.9 | 38 | 0 |
15 | Locked | 40.9 | 37 | 0 |
16 | Locked | 40.9 | 60 | 0 |
17 | Locked | 40.9 | 51 | 0 |
18 | Locked | 40.9 | 33 | 0 |
19 | Locked | 40.9 | 56 | 0 |
20 | Locked | 40.3 | 48 | 0 |
21 | Locked | 40.9 | 47 | 0 |
22 | Locked | 40.9 | 54 | 0 |
23 | Locked | 40.3 | 31 | 0 |
24 | Locked | 40.9 | 77 | 0 |
1 | 46200000 | 44.3 | 5120 | 64 qam | 2 |
2 | 53700000 | 44.8 | 5120 | 64 qam | 1 |
3 | 39400000 | 44 | 5120 | 64 qam | 3 |
4 | 32600000 | 44.5 | 5120 | 64 qam | 4 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 1 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | cmreg-vmdg505-bbt057-b.cm |
on 17-09-2022 07:22
SFID | 62788 |
Max Traffic Rate | 117000047 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 62787 |
Max Traffic Rate | 10500047 |
Max Traffic Burst | 16320 |
Max Concatenated Burst | 16320 |
Scheduling Type | BestEffort |
16/09/2022 16:39:16 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0; |
15/09/2022 02:11:56 | critical | No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=CM-QOS=1.1;CM-VER=3.0; |
14/09/2022 17:05:59 | notice | LAN login Success;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0; |
14/09/2022 12:12:3 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0; |
14/09/2022 09:46:50 | notice | LAN login Success;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0; |
14/09/2022 09:38:40 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0; |
14/09/2022 09:38:30 | notice | Unit has been restored to factory defaults from a software issued command;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0; |
14/09/2022 09:27:31 | notice | LAN login Success;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0; |
14/09/2022 09:18:59 | notice | NOTICE ATOM is restarted due to Kernel/oops panic as part of Self Healing Mechanism ;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 14:37:12 | critical | No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0; |
13/09/2022 08:56:59 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0; |
11/09/2022 22:01:48 | critical | No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0; |
11/09/2022 07:14:0 | notice | Unit has been restored to factory defaults from a software issued command;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0; |
10/09/2022 19:20:31 | notice | LAN login Success;CM-MAC;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0; |
10/09/2022 19:20:24 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=:1b;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0; |
10/09/2022 14:24:8 | notice | LAN login Success;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0; |
08/09/2022 10:37:25 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=:1b;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0; |
07/09/2022 18:09:34 | critical | No Ranging Response received - T3 time-out;CM-MAC=c;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0; |
01/09/2022 16:16:18 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-b;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0; |
31/08/2022 15:04:28 | critical | No Ranging Response received - T3 time-out;CM-MAC=;CMTS--QOS=1.1;CM-VER=3.0; |
