on 19-11-2021 21:48
I just got VM for the first time (house move) and have been advised that to run my home network (all of which expects gateway at 192.168.1.1), I should use a separate router and set the VM Hub 3 to modem mode. I had a Huawei HG635 router lying around from TalkTalk days, so had a play around this evening without managing to get it to work, though I now realise I made some mistakes. I have three questions:
1. Does anyone know if the HG635 should/shouldn’t work with the Hub 3?
2. The HG635 has 4 Ethernet ports and 1 WAN port. Do I connect an Ethernet cable between Port 1 on the Hub and the WAN port on the HG635 - or an Ethernet port on the HG635?
3. Presumably, I must move the TV Ethernet connection from the Hub to one of the other ports on the HG635?
many thanks in advance for any help!! My knowledge of networking is pretty basic
Answered! Go to Answer
on 20-11-2021 12:41
Set access mode to Ethernet. There are two parts to DHCP on a router, it’s a server for DHCP on the LAN, in your case 192.168.1.x and a client for the DHCP on the WAN side. They are two separate entities.
on 19-11-2021 22:05
1) should work
2) WAN port
3) yes
How to put a VM hub into modem mode:
1) Access your hub on 192.168.0.1, sign on and put it into modem mode. On the Hub3 the bottom LED will change to magenta. Best done from a wired connection.
2) Turn off the hub and disconnect any Ethernet cables
3) Fully initialise your own router and make sure the WAN port is set to DHCP
4) Connect your router to the VM hub with an Ethernet cable, Cat5e or Cat6, any higher specification is a waste of money
5) Turn on the VM hub.
6) You should now be able to access the internet and the hub will now be on 192.168.100.1
on 20-11-2021 11:12
on 20-11-2021 12:41
on 20-11-2021 20:58
All worked like a charm - very happy! So many thanks for the help.
bryn
on 28-12-2021 10:59
I'm just setting up my HG635 with the Virgin Hub 3.0 in modem mode. Did you set the WAN / internet connection as bridged on HG635, I followed the thread and set it up the same as mentioned but don't get any internet connection.
on 28-12-2021 11:13
Reset the HG635 back to factory settings and try again. Set the WAN port to Ethernet and make sure your are powering on the Hub (in Modem mode) in the correct order, i.e. last
on 29-12-2021 11:46
on 29-12-2021 14:08
Have you set the VM Hub in Modem mode? What port on the Hub have you connected to the Router? As an aside, you are aware you can only have one cable into the Hub when in Modem mode. Can you connect to 192.168.100.1 from a cable connected to the Router.? Are you getting a WAN IP on your Router. Do not use wifi for test connections, you should use a cabled connection into your Router.
