Hi I would appreciate some advice with my guest network
Are the speeds delivered on the guest network the same as the home network or are drops to be expected? I'm not quite sure because even though they are separate networks they still go through the same router? Also, is the VHUB3 guest network as secuure as the home network is?
Thanks alot for any help
