  • 37
tkdsouth
Message 1 of 7
Green light the WiFi icon, keep flashing every 10 minutes or so. Disconnects me from internet.
I have only had this new box for a a few days and for some reason I keep getting disconnected every 10 minutes or so. I look up at the box (I’m in the same room) and the green WiFi icon is flashing away.
I can reconnect quickly but it is very frustrating.
Could it be the new box or is there a problem with VM at the moment?
  • 2.39K
  • 76
  • 117
Message 2 of 7
Re: Green light the WiFi icon, keep flashing every 10 minutes or so. Disconnects me from internet.
Hi tkdsouth,
Thank you for your post. My apologies for any issues.
Is this happening on multiple devices? Do you have any issues with a Wired connection?
^Martin
  • 37
tkdsouth
Message 3 of 7
The green icon is still flashing right now and has been since I wrote this post.
Only the wireless devices are being disconnected, all of them.
  • 6.13K
  • 470
  • 1.02K
Hero
Message 4 of 7
It’s irrelevant if the OP is using a wired of WiFi connection. Flashing LEDs usually mean a drop of connection on the circuit. What the hub is trying to do is reconnect and it’s not succeeding.
Go into your hub on 192.168.0.1 and post your up/downstream stats and network log.
  • 37
tkdsouth
Message 5 of 7
I will look for it now.
  • 37
tkdsouth
Message 6 of 7
What setting in the left side bar do I need to click to find this upstream information thank you.
  • 4.57K
  • 311
  • 277
Message 7 of 7
Hi Tkdsouth,
If you go to http://192.168.0.1/ but don’t log in. You'll then need to click "check router status" and then copy and paste in the full the downstream power levels and the upstream power levels.
I hope that helps.
Emma_C - Forum Team
