on 26-04-2022 08:27
I have the green flashing WiFi light on my Hub3 this morning. No reported connection problems i the area.
I’ve tried going through all the settings from advice on here but nothing has worked yet. Rebooted and Reset the modem but still not working…
I use the internet for work and need it sorting asap! Any advice??
on 26-04-2022 08:59
Do wired connections work?
What does the hub status page show?
have you rang the ‘local’ number for known faults?
