Amc1231
Message 1 of 5
Green base light flashing. Have checked and restarted all connections
How do I pm to get a diagnostic run?
lotharmat
  • 947
  • 70
  • 143
Well-informed
Message 2 of 5
Re: Green base light flashing. Have checked and restarted all connections
I would factory reset the hub!
remove any ethernet cables
Ensure you can read the login details for the hub (on the bottom or on the card)
Press and hold the reset switch for 60 seconds with a paperclip or sim-removal tool
Give it about 10 minutes to see if it comes back - if not call 150 and raise it as a fault!
Amc1231
Message 3 of 5
Hi did that last night but still flashing green light. Have just done so again. Waiting 10 mins.
lotharmat
  • 947
  • 70
  • 143
Well-informed
Message 4 of 5
Sounds like something is totally broken - Hopefully VM will be along shortly to diagnose!
Jodi_S
  • 1.79K
  • 105
  • 185
Message 5 of 5
Hi Amc1231,
Welcome to our community and thanks for posting. Really sorry to hear that you're experiencing issues with our hub, as its been a short while since you last posted how have things been?
Is your hub still flashing with the green light? Do you have any connection at all?
Please let us know so we can assist you further.
Kind regards Jodi.
