on 09-03-2021 10:16
Hi I’ve recently been experiencing with my Google WiFi Nest. This used to work fine but now the Mesh signal is weak and often drops out completely. It says move the Google WiFi points closer together but even when I have them right next to each other it still shows a weak Mesh. I’ve recently moved to a V6 set top box so wondering if it might be that. I’ve tried contacting Virgin but get told they can’t help with third party devises however from looking through this forum this seems to be a common issue. I’ve seen suggestions that I should put the Hub3 into Modem mode but I’m no IT expert and worry what the knock on effect might be (will it impact my TV or WiFi connection?). If this is recommended how do I go about it? I’ve also read that Upstream/Downstream speeds might be an issue so have attached my diagnostics.
Any help gratefully received.
Answered! Go to Answer
on 09-03-2021 10:29
on 09-03-2021 10:42
modem mode is the recommended way to set this up.
follow these instructions to put the hub into modem mode and get the google wifi mesh set up.
Log into the hub on http://192.168.0.1 and select the option to put the hub into modem mode
The hub will then reboot and come back up in modem mode - give it five minutes to settle down
Disconnect all ethernet cables from the hub
Power off the Hub and your router/mesh system
Connect your router/mesh system to the hub via ethernet cable and switch it on - leave it five minutes to settle down
Power on the hub and leave it five minutes to settle down
Should all be working.
on 09-03-2021 10:46
Thanks for that. I’ll give it a try. Just one final question - once the Hub is in Modem mode should I also continue to connect my V6 set top box via Ethernet into the Hub?
on 09-03-2021 11:00
on 09-03-2021 11:13
Yup - you got it.
as for which port - it used to be the case that you had to use the port closest to the power plug on the hub, but i believe this was phased out with the hub3, so you can use any of the ports..
on 09-03-2021 10:29
on 09-03-2021 10:38
Thanks so much for the reply. I’m afraid I’m a bit of a Luddite when it comes to these things. I will try to put the hub into Modem mode but is there any downside to doing this and is it reasonably straight forward to reverse it if it all goes wrong? Should just doing this fix the problem do you think?
Can you elaborate about what you mean by only having the Google mesh node wired to the hub? I have the Google WiFi hard wired into the hub but also have by set top box hard wired into the back of the hub.
Thank you so much for all your help
on 09-03-2021 10:42
on 09-03-2021 10:46
on 09-03-2021 11:00
on 09-03-2021 11:05
Thanks so my set up should be:
1) connect Google WiFi node via Ethernet into the back of the Hub
2) connect V6 set top box via Ethernet into the back of the Google node
Is that all correct?
When you say only one port on the hub will work how do I know which of the 4 ports I should use?
Thank you so much for walking me through this.
on 09-03-2021 11:13
Yup - you got it.
on 09-03-2021 11:16
Thank you so much for your patience and exceptionally prompt responses.
on 09-03-2021 11:20
