dougweller
  • 22
Message 1 of 7
Getting 1gb and of course Hub 5, advice on need to replace BT home extenders
I've got the ordinary Whole Home, which works ok on 500m, but do I need the Premium? Or something else? I use ethernet cabling to connect to the living room for the tv and upstairs for my wife and am getting that upgraded.
Thanks.
Doug
  • 1.8K
  • 109
  • 407
Super solver
Message 2 of 7
Re: Getting 1gb and of course Hub 5, advice on need to replace BT home extenders
If the current Whole Home installation is working why touch any of it.
An extra 500Mb/s at the Hub is not going to make a jot of difference to your TVs or to most other WiFi kit when doing normal tasks.
dougweller
  • 22
Message 3 of 7
That  makes sense. I'm having someone to the ethernet rewiring anyway and they can test that.
dougweller
  • 22
Message 4 of 7
Seems as though Cat5 is still fine for 1gig.
Doug
  • 1.8K
  • 109
  • 407
Super solver
Message 5 of 7
CAT5 cables were made to about year 2001.
Possibly the cables are from 2001 or later and are CAT5e which is fine for 10/100/1000 Mb/s.
dougweller
  • 22
Message 6 of 7
They  must be then as they were installed about 2008. Thanks.
  • 35.06K
  • 3.41K
  • 6.67K
Message 7 of 7
Unless the installer was using up some of their old stock 🙂
If they are Cat5e - then Cat5e will be printed on the cable sheathing.
Can you see or reveal any of it ?
