Symon
Message 1 of 8
Frequent loss of internet daily and always 2300-0100hrs
Hi, for months now we have had frequent (not always same time) daily loss of internet service both wireless and hard wired (tv is ok) but also total loss of interent between 2300 and 0100hrs every night. Heres the downstream and upstream data. Any ideas? thanks
Upstream  US-1 US-2 US-3 US-4
Channel Type2.02.02.02.0
Channel ID11131210
Frequency (Hz)32600000537000002580000039400000
Ranging StatusSuccessSuccessSuccessSuccess
Modulation64QAM64QAM32QAM64QAM
Symbol Rate (Sym/sec)5120000512000051200005120000
Mini-Slot Size4244
Power Level (dBmV)44.0044.0043.0044.00
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0000
T4 Timeouts0000
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)251000000203000000211000000219000000227000000235000000243000000259000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID159101112131416
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)1.222.422.132.091.911.471.341.30
RxMER (dB)37.3637.6437.3637.6438.2637.9437.9437.64
Pre RS Errors16214687403997329352372387
Post RS Errors305304285915291308303289
  • 19.22K
  • 1.68K
  • 4.22K
Message 2 of 8
Re: Frequent loss of internet daily and always 2300-0100hrs
can you post the network log, since nothing showing a miss with the signal levels.
If someone's helped you out say thanks by clicking on the thumbs up on kudos. If someone's solved your problem, why not mark their message as an Accepted Solution, but only do this once issue has been resolved.
Symon
Message 3 of 8
First Time Last Time Priority Error Number Description
09/01/2019 18:48:12 GMT 09/01/2019 18:48:12 GMT Error (4) 68010302 DHCP WAN IP - ############
09/01/2019 18:47:19 GMT 09/01/2019 18:47:19 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
06/01/2019 09:40:09 GMT 06/01/2019 09:40:09 GMT Error (4) 68010302 DHCP WAN IP -  ############
06/01/2019 09:39:16 GMT 06/01/2019 09:39:16 GMT Error (4) 68000407 TOD established
06/01/2019 05:03:11 GMT 06/01/2019 05:03:11 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
05/01/2019 18:24:27 GMT 05/01/2019 18:24:27 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
02/01/2019 12:20:34 GMT 02/01/2019 12:20:34 GMT Notice (6) 68010600 DHCP Renew - lease parameters tftp file-******** modified
02/01/2019 12:20:34 GMT 02/01/2019 12:20:34 GMT Error (4) 68010400 DHCP REBIND WARNING - Field invalid in response
02/01/2019 12:19:39 GMT 02/01/2019 12:19:39 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
02/01/2019 12:18:47 GMT 02/01/2019 12:18:47 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
02/01/2019 12:17:03 GMT 02/01/2019 12:17:03 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
02/01/2019 12:13:34 GMT 02/01/2019 12:13:34 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
02/01/2019 12:06:37 GMT 02/01/2019 12:06:37 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
02/01/2019 11:52:43 GMT 02/01/2019 11:52:43 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
02/01/2019 11:24:54 GMT 02/01/2019 11:24:54 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
02/01/2019 10:29:16 GMT 02/01/2019 10:29:16 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
02/01/2019 08:38:01 GMT 02/01/2019 08:38:01 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
02/01/2019 04:55:30 GMT 02/01/2019 04:55:30 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
[MOD EDIT - Personal IP address removed]
  • 15.2K
  • 653
  • 32
Moderator (Retired) John_G
Moderator (Retired)
Message 4 of 8
Hi Symon,
I've just tried to run some tests on your connection from here but have been unable to locate your account.
I've just sent you a private message requesting some information so that we can investigate further.
  • 15.2K
  • 653
  • 32
Moderator (Retired)
Message 5 of 8
Hi Symon,
Thanks for getting back to me and passing security. I've now checked your account and can see there is a contention fault in the area but this wouldn't cause disconnections.
All your other stats look healthy, power levels and SNR are stable and can see the hub has been online consistently for over 48 hours since last reboot.
How has your connection been in that time?
Symon
Message 6 of 8
We still have problems with both wifi and wired internet connections dropping out anytime after about 2200hrs (sometimes 2100hrs) almost every day.
  • 8.6K
  • 882
  • 1.33K
Message 7 of 8
Set up a free BQM (only takes 1 minute) - to continually to monitor the state of your connection and any dropouts, 24/7/365 and it keeps a visual record of all of your network disconnection data.
  • 2.19K
  • 81
  • 152
Message 8 of 8
Hi Symon,
Did you manage to set up the BQM? If so, could you post the results?
Kind regards,
John_GS
