23-07-2021 20:46 - edited 23-07-2021 20:48
I'm experiencing frequent and regular connection/disconnection issues with my Hub 4. I didn't think anything of it at first but when I noticed the pattern of it happening pretty much daily at around the same time I went to inspect the hub.
The white coax cable that connects to the wall socket seems to be getting unusually hot at the end where it's connected to the hub. Coincidentally when I went to touch the cable to see if it's connected properly, the hub reset and connection was back up. I imagine it could be some sort of voltage issue that's causing the cable to heat up and the hub to disconnect?
What can be done about this?
Appreciate any support.
on 24-07-2021 13:33
on 26-07-2021 08:58
Good morning @Mike_G44
Welcome to the forums and thank you for taking the time to post.
I am sorry to hear that you have had some issues with disconnections.
I have taken a look over the account and run some diagnostics, on the account, there seems to be a capacity issues with your broadband that could be coursing some of these issues. However It is worrying that the coax is overheating, did you manage to call the technical support team regarding this?
Kind regards,
Zak_M
26-07-2021 09:46 - edited 26-07-2021 09:47
Hi Zak,
Thank you both for your input and advice first.
I will be calling up tech team today and will update you on the situation.
Are you able to elaborate on the capacity issues?
Thanks.
on 26-07-2021 10:03
Thank you for coming back to me.
I can sort that out for you, no need to call the team.
Capacity issue is basically means that some of the devices connected 2.4ghz and the 5.0ghz are on the wrong bands, the easiest way to resolve this is to turn off the devices and back on again, Alternatively you can split the SSIDs and assign each device.
Kind regards,
Zak_M
