on 15-10-2022 22:47
HI,
After a few quiet days my Hub 5 seems to be having a fit again, my Googling efforts all seem to indicate a cable issue from the street box or a dodgy splitter, they are all NTL installed, is it possible to have the attached log sent to a company expert for their views? Or a Tech visit to check the signal loss issues? I am beginning to think this 1 gig and Hub 5 are unfit for purpose. The log starts below I have highlighted all obvious errors.
Cable Modem Status | ||
Item | Status | Comments |
Acquired Downstream Channel(Hz) | 331000000 | Locked |
Ranged Upstream Channel(Hz) | 49600000 | Ranged |
Provisioning State | Online | Operational |
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
1 | 331000000 | 7.4 | 40 | QAM 256 | 25 |
2 | 211000000 | 6.5 | 39 | QAM 256 | 10 |
3 | 219000000 | 6.4 | 39 | QAM 256 | 11 |
4 | 227000000 | 6.2 | 39 | QAM 256 | 12 |
5 | 235000000 | 5.6 | 39 | QAM 256 | 13 |
6 | 243000000 | 5.5 | 39 | QAM 256 | 14 |
7 | 251000000 | 5.9 | 39 | QAM 256 | 15 |
8 | 259000000 | 6.4 | 40 | QAM 256 | 16 |
9 | 267000000 | 6.8 | 40 | QAM 256 | 17 |
10 | 275000000 | 7.3 | 40 | QAM 256 | 18 |
11 | 283000000 | 7.6 | 40 | QAM 256 | 19 |
12 | 291000000 | 7.7 | 40 | QAM 256 | 20 |
13 | 299000000 | 7.8 | 40 | QAM 256 | 21 |
14 | 307000000 | 7.7 | 40 | QAM 256 | 22 |
15 | 315000000 | 7.8 | 40 | QAM 256 | 23 |
16 | 323000000 | 7.7 | 41 | QAM 256 | 24 |
17 | 339000000 | 7.5 | 39 | QAM 256 | 26 |
18 | 347000000 | 7.8 | 41 | QAM 256 | 27 |
19 | 355000000 | 7.9 | 41 | QAM 256 | 28 |
20 | 363000000 | 8.2 | 41 | QAM 256 | 29 |
21 | 371000000 | 8 | 41 | QAM 256 | 30 |
22 | 379000000 | 7.8 | 41 | QAM 256 | 31 |
23 | 387000000 | 8 | 41 | QAM 256 | 32 |
24 | 395000000 | 7.9 | 41 | QAM 256 | 33 |
25 | 403000000 | 7.7 | 41 | QAM 256 | 34 |
26 | 411000000 | 7.6 | 41 | QAM 256 | 35 |
27 | 419000000 | 7.4 | 41 | QAM 256 | 36 |
28 | 427000000 | 7.5 | 41 | QAM 256 | 37 |
29 | 435000000 | 7.5 | 41 | QAM 256 | 38 |
30 | 443000000 | 7.3 | 41 | QAM 256 | 39 |
31 | 451000000 | 7.9 | 41 | QAM 256 | 40 |
Channel | Locked Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
1 | Locked | 40 | 274 | 621 |
2 | Locked | 39 | 142 | 250 |
3 | Locked | 39 | 129 | 256 |
4 | Locked | 39 | 432 | 1049 |
5 | Locked | 39 | 159 | 254 |
6 | Locked | 39 | 210 | 403 |
7 | Locked | 39 | 474 | 1048 |
8 | Locked | 40 | 447 | 1021 |
9 | Locked | 40 | 396 | 876 |
10 | Locked | 40 | 299 | 692 |
11 | Locked | 40 | 391 | 806 |
12 | Locked | 40 | 312 | 552 |
13 | Locked | 40 | 269 | 478 |
14 | Locked | 40 | 274 | 746 |
15 | Locked | 40 | 245 | 433 |
16 | Locked | 41 | 302 | 655 |
17 | Locked | 39 | 226 | 627 |
18 | Locked | 41 | 226 | 580 |
19 | Locked | 41 | 245 | 493 |
20 | Locked | 41 | 173 | 481 |
21 | Locked | 41 | 213 | 481 |
22 | Locked | 41 | 198 | 388 |
23 | Locked | 41 | 171 | 386 |
24 | Locked | 41 | 174 | 360 |
25 | Locked | 41 | 160 | 289 |
26 | Locked | 41 | 161 | 290 |
27 | Locked | 41 | 127 | 254 |
28 | Locked | 41 | 128 | 233 |
29 | Locked | 41 | 121 | 183 |
30 | Locked | 41 | 117 | 141 |
31 | Locked | 41 | 127 | 112 |
Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
0 | 49600000 | 42.5 | 5120 | QAM 64 | 1 |
1 | 43100000 | 42 | 5120 | QAM 64 | 2 |
2 | 36600000 | 41.5 | 5120 | QAM 64 | 3 |
3 | 30100000 | 41.5 | 5120 | QAM 64 | 4 |
4 | 23600000 | 41 | 5120 | QAM 64 | 5 |
Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 18 | 0 |
General Configuration
Network access | Allowed |
Maximum Number of CPEs | 3 |
Baseline Privacy | Enabled |
DOCSIS Mode | 3.1 |
Config file | ccsp.boot This has changed? |
SFID | 2962 |
Max Traffic Rate | 1200000450 bps |
Max Traffic Burst | 42600bytes |
Min Traffic Rate | 0 bps |
SFID | 15485 |
Max Traffic Rate | 128000 bps |
Max Traffic Burst | 4000bytes |
Primary Upstream Service Flow
SFID | 2961 |
Max Traffic Rate | 55000270 bps |
Max Concatenated Burst | 16320bytes |
Scheduling Type | Best Effort |
SFID | 15489 |
Max Concatenated Burst | 1522bytes |
on 15-10-2022 22:47
And the rest
Time | Priority | Description |
15-10-2022 14:33:44 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 14:33:44 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 13:31:52 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 13:31:52 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 07:09:55 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 07:09:55 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 07:01:34 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 06:43:15 | warning | Dynamic Range Window violation |
15-10-2022 06:43:15 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 06:16:39 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 06:16:39 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 06:12:39 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 06:11:18 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 06:10:39 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 06:09:30 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 06:08:59 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 06:08:39 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 06:07:39 | warning | Dynamic Range Window violation |
15-10-2022 06:07:39 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 06:07:00 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 06:06:39 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 06:04:44 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 06:03:24 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 06:02:12 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 06:02:12 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 06:01:44 | warning | Dynamic Range Window violation |
15-10-2022 06:01:44 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-10-2022 05:28:56 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 15-10-2022 22:50
on 18-10-2022 08:44
Hey Osram, thank you for reaching out and I am sorry you are having some connection issues.
I have taken a look from my side and I can see there is a short term connectively issues in your area.
This is expected to last for 24 hours, please can you reach out within the next 24 hours if you are having any issues. Thanks
Matt - Forum Team
New around here?
on 18-10-2022 12:53
Hi Legacy1
As requested please find the BQM below. Sorry it's taken a while to reply but have been busy making changes to boiler controller and fixing issues with it.
I think the hub may have updated during last night as the logs have reset and have already started adding faults again, also the config file has changed again:-
Config file
wrkldJKDHSUBsgvca69834ncxv987 |
Regards Osram
on 18-10-2022 13:29
Hi Matt
These issues have been occurring since the 1gig and Hub 5 was installed on 10/09/22, which you should be aware of since I messaged you directly 3 weeks ago in connection with a previous post "Hub 5 overnight software updates", maybe you didn't receive this as you did not reply?. I also note that the "Check Service Status" reports no issues with broadband locally today as shown below;-
When I posted "Hub 5 overnight software updates" I feel that I clearly conveyed that the reboots were occurring at midnight. your reply to this was "Normally we would release updates at around midnight, which can cause some disconnections. Is it only at midnight this is happening?"
Did you read my post?
0sram
on 20-10-2022 14:13
Hey Osram, thank you for reaching out with an upgrade and I am sorry to see you are having connection issues.
I will send you a PM now so we can look into this, please look out for the purple envelope. Thanks
Matt - Forum Team
New around here?
