Flashing red light on my hub
rugal316
Hi everyone
Been with virgin media for a few months, and randomly my virgin media hub has been flashing red for 2 days, did all the checks for outages etc.. and nothing. Restarted the hub didn't work. I have been without internet for 2 days and I work from home so I need it, I can't seem to get hold of a human when I call as well.
1 ACCEPTED SOLUTION
Accepted Solutions
Have you checked first for any “known network faults in your location - Look in 2 places
1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
Then if nothing is reported there, then see this to report the fault...
______
There are a few options. Firstly call it in on the “faults” line - on 150 (VM Phone - free) or 0345 454 1111 (any other phone - national rate). Use option 2 (faults), dont press any other buttons when offered and you should be in the queue for the next agent.
If you get cut off after an automated reboot cycle, just call back in a couple of minutes as the system should know that you have just been on and it hasn’t helped and put you in the queue.
Try now, but calling at 08.00 midweek (09.00 Sun) is the best time to get through quickly at busy/closed times you may get redirected to offshore - hence calling early is best.
You can text VM on 0753 305 1809 include account name/number and what the issue is, there is also a “Chat” option on their website - but note that replies usually take longer. Or you can speak to the team on WhatsApp by logging into your online account via a mobile handset and there will be a link to speak to VM by Whats App (the number is 0780 3089 684 ) - you can use the same number for their other social media platforms too (TwitX/Fbook. etc) - so try them all.
FINALLY… A VM person will pick this up on here and respond, but it can take a few days for them to get here.
I do not work for VM. My services: HD TV on VIP (+ Sky Sports & Movies & TNT sport), x3 V6 boxes (1 wired, 2 on WiFi), Hub5 in modem mode with Apple Airport Extreme Router +2 Airport Express's & TP-Link Archer C64 WAP. On Volt 350Mbps, Talk Anytime Phone, x2 Mobile SIM only iPhones.
2 REPLIES 2
______
John_GS
Hi @rugal316
I'll go ahead and send you a PM now to assist further.
Best wishes.
John_GS
