on 03-08-2021 10:01
As it says. The light at the bottom is flashing green. The WiFi light is solid green. I’ve checked connections etc. All good. I tried booking an engineer but not sure it worked as it shows as no upcoming appointments on the app. Any help appreciated.
on 03-08-2021 13:55
on 03-08-2021 14:01
Hi Mark1871,
Have you performed the diagnostics on the following page? Router lights
I notice you said you tried to arrange an engineer, but nothing is showing in your app.
If there is a local fault then the engineer appointment would be cancelled so check the Service Status number on 0800 561 0061. This often gives details of more local issues down to postcode level.
As well as your app you can also check if an appointment is showing in MyVirginMedia at the top of the page.
Click on the Help tab (next to My Upgrades and Offers and Service Status); if you hover over that tab, a new menu will appear.
Scroll on over to the Orders and Appointments tab and click ok.
Providing it's been arranged the visit will show there, and you can reschedule from there if the timeslot booked is not convenient for you.
on 05-08-2021 13:36
Hi Mark1871
Thanks for posting. I'm really sorry to hear that you have had some service issues.
I've not been able to locate your account via the forum details provided - do you still need assistance?
Please keep us posted if so and we'll be more than happy to help
Kind regards,
on 02-09-2021 17:04
Sorry I thought I had posted that the problem was now solved. Apologies.
on 05-09-2021 09:54
Hi @Mark1871,
Thanks for coming back to us.
Glad to hear the problem has been sorted 🙂
Have a lovely day.
