on 07-05-2023 01:19
The wifi was working fine all day and me and my boyfriend was watching tv and it said we were experiencing buffering and then the wifi cut off so we tried everything to reconnect it we went onto diagnostic and it said the hub couldn’t connect to the wifi.
the hub started flashing blue and wouldn’t stop we’ve reset, we’ve turned it off at the wall, checked all wires are properly plug in and nothing works and we’re having to use data because there’s no wifi.
on 07-05-2023 02:01
I came here for the same reason everything just dropped, so did a complete reboot, then still the flashing blue light no WiFi tried a factory reset as advised on another thread, went white for a while then back to flashing blue light, no one available to take calls at support this bank holiday weekend by looks of things. Very annoyed.
on 07-05-2023 02:35
Well seems that we are alot that we have the same problem so wont be solved until morning or worst..Tuesday. Virgin media sucks in case of helping customers. No where to call or get help..just bot's that sends you at the same point over and over.
on 07-05-2023 06:19
Hi. Looks like we are having the same problem. 2am onwards. Where is everyone based roughly. We are Lincolnshire
on 07-05-2023 06:28
And literally as I posted my reply. Everything started up again. Be sure to hit the reset button on the bottom and leave it. Hope everyone gets sorted 👍
on 07-05-2023 07:33
Yeah its back in NG15
