on 11-08-2022 10:00
Since i got the hub 4 i cant get my 4k Amazon firestick to connect to the network, it sees the wifi but wont establish a connection to it, i have tried taking the adapter out rebooting, seperating the 2.4ghz and 5 ghz ssids, the firestick connected to the hub 3 no problem also all the other devices in the household connect up to the hub 4 but this firestick and my laptop it is very strange.
on 12-08-2022 16:46
Same here. Connects sometimes but then disconnects and won’t reconnect? 🤷🏻♂️
on 12-08-2022 16:51
Try a 60 pinhole reset on the Hub. Also a wired connection would be best for the firestick.
on 12-08-2022 17:00
That’s actually worked. Thank you
on 16-08-2022 09:00
Hi Kieranmick,
Thanks for your post and it's great having you back in the Community.
We're sorry to hear you're having an issue getting your Firestick to connect to the Hub.
I can see another user has had success off the back of the post by Adduxi saying to complete a pin hole reset on the hub. Can you also try this and let us know how it goes?
on 16-08-2022 13:52
i have reseted it, put it back to factory settings think it may be a fault with the hub, i have an engineer coming today
on 18-08-2022 14:47
Hi there @Kieranmick
Thank you for letting us know, now it's been a few days since the visit how are things looking?
What did the engineer say when they came?
Thanks again.
on 18-08-2022 15:27
the hub 4 was actually faulty, it had been delivered by courier so engineer thinks it may have been thrown about in its packaging which had led to it being defected. engineer was great discovered that the frequencies were out and replaced the hub and it fixed the issues 👍
on 18-08-2022 15:50
Do you remember the SSID name on the old hub? If you do, rename the hub 4 SSID to the same name, should connect straight away. Worked with all the hubs i have had in the past.
on 21-08-2022 11:15
Glad to hear the issue was resolved with our team @Kieranmick.
Please do not hesitate to contact us if you need any further help.
