on 17-08-2021 13:36
Hi, since April connection cuts out very frequently. Over last few months this has been between every minute to every hour. It cuts out sometimes for a few seconds and hub light stays orange / pink and other times for a few minutes with hub light changing colour. Have a technician coming on Thursday after past two have been cancelled due to faults in the area which were subsequently fixed but didn't fix my issue.
Following guidance on this website and pasting link to broadband tracking started yesterday. Please can you provide me with any advice or fault identification would be good to get fixed.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/33c8bc39cf84e3b843cc34a6f847e5bfddd07ded-17-08-2021
on 17-08-2021 13:42
SFID | 244073 |
Max Traffic Rate | 22000061 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
Max Concatenated Burst | 42600 |
Scheduling Type | BestEffort |
on 17-08-2021 13:43
17/08/2021 09:28:56 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 09:28:51 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 09:28:50 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 09:28:50 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 09:17:7 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 09:17:2 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 09:17:2 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 09:00:9 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 09:00:4 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 09:00:3 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 08:57:55 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 08:57:51 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 08:57:51 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 08:57:50 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 08:55:20 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 08:55:13 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:* |
on 17-08-2021 13:43
Way too many T3’s on the upstream. Cannot go by the Pre & Post RS errors, which do look very bad, but all these figures are accumulative since the hub was last power cycled. Please power cycle your hub and post a new set of stats in a few hours. Most probably cause in noise ingress.
on 17-08-2021 13:44
on 17-08-2021 13:45
Thanks, Lotharmat. Turned off at wall today and re-installed cables /splitter into wall etc again. Think I restarted y'day or day before but can have another go now. Will have restarted with rest button lots of times over last few months due to persistent issues.
on 17-08-2021 13:46
on 17-08-2021 13:47
Will do. Thanks Lotharmat and Tudor.
on 17-08-2021 14:21
on 17-08-2021 14:52
Here's where we are at now, can repost in a few more hours in case it provides a better picture (thanks again for the help):
Acquired Downstream Channel (Hz) | 203000000 | Locked |
Ranged Upstream Channel (Hz) | 53700263 | Locked |
Provisioning State | Online |
on 17-08-2021 14:53
1 | 203000000 | 5.6 | 38 | 256 qam | 9 |
2 | 211000000 | 5.5 | 38 | 256 qam | 10 |
3 | 219000000 | 5.6 | 40 | 256 qam | 11 |
4 | 227000000 | 5.6 | 38 | 256 qam | 12 |
5 | 235000000 | 5.8 | 40 | 256 qam | 13 |
6 | 243000000 | 5.8 | 40 | 256 qam | 14 |
7 | 251000000 | 5.6 | 40 | 256 qam | 15 |
8 | 259000000 | 5.5 | 38 | 256 qam | 16 |
9 | 267000000 | 5.1 | 40 | 256 qam | 17 |
10 | 275000000 | 5.1 | 38 | 256 qam | 18 |
11 | 283000000 | 4.8 | 38 | 256 qam | 19 |
12 | 291000000 | 5 | 40 | 256 qam | 20 |
13 | 299000000 | 4.5 | 38 | 256 qam | 21 |
14 | 307000000 | 4.9 | 38 | 256 qam | 22 |
15 | 315000000 | 4.5 | 38 | 256 qam | 23 |
16 | 323000000 | 4.8 | 40 | 256 qam | 24 |
17 | 331000000 | 4.8 | 40 | 256 qam | 25 |
18 | 339000000 | 5 | 38 | 256 qam | 26 |
19 | 347000000 | 5.1 | 40 | 256 qam | 27 |
20 | 355000000 | 5.1 | 40 | 256 qam | 28 |
21 | 363000000 | 5 | 40 | 256 qam | 29 |
22 | 371000000 | 5 | 40 | 256 qam | 30 |
23 | 379000000 | 5.1 | 40 | 256 qam | 31 |
24 | 387000000 | 4.8 | 40 | 256 qam | 32 |
1 | Locked | 38.6 | 32 | 5567 |
2 | Locked | 38.9 | 21 | 3464 |
3 | Locked | 40.3 | 419 | 2315 |
4 | Locked | 38.9 | 245 | 2698 |
5 | Locked | 40.3 | 468 | 2511 |
6 | Locked | 40.3 | 434 | 2613 |
7 | Locked | 40.9 | 434 | 2589 |
8 | Locked | 38.9 | 468 | 2449 |
9 | Locked | 40.3 | 405 | 8016 |
10 | Locked | 38.9 | 391 | 1901 |
11 | Locked | 38.9 | 379 | 2439 |
12 | Locked | 40.3 | 304 | 2585 |
13 | Locked | 38.9 | 188 | 3187 |
14 | Locked | 38.9 | 24 | 3245 |
15 | Locked | 38.9 | 21 | 3320 |
16 | Locked | 40.9 | 27 | 3472 |
17 | Locked | 40.3 | 8 | 3316 |
18 | Locked | 38.9 | 28 | 3422 |
19 | Locked | 40.9 | 47 | 3844 |
20 | Locked | 40.3 | 29 | 4387 |
21 | Locked | 40.3 | 22 | 4472 |
22 | Locked | 40.3 | 29 | 3988 |
23 | Locked | 40.9 | 26 | 3833 |
24 | Locked | 40.3 | 22 | 4584 |
